Originally posted by fluoir View PostHow can I install windows drivers for my box with this rom please? My box isn't showing in windows' device manager at all not even under other devices..."HANDS ARE NATURES FORKS" -Rigby
Hi, I'm struggling with how to get WiFi working on my a95x, the WiFi never turned on in stock, I installed xannytech hoping it would fix it. It didn't. I copied across the files in op for ap6330, changed permissions, but still did not work. What other drivers are there not included that I might need? I read an earlier post about ap6212 and ap6212A? Is there anyway to find out? It just keep trying to turn WiFi on, it's like when I installed s812 ROM on an s802 device.
Any help much appreciated.
Hello.
I would like to get a help...
This ROM is working perfectly in mine m8s II.
But i said here before i was having some problems with the sound.
I saw that in another box i had the same problem ... but the box had another app called FreeTV Pro and it solve the sound problem.
So the app solved it because it download codecs when it sees it need them to play a stream or a movie.
But the app is not compatible with this device, thats what it says.
Is is possible to make it compatible with our ROM ?
The app is here .
Cumps
The app is here .
Cumps
Originally posted by Dandroid534 View Post
What are you trying to play? Probably a lot easier to find an alternative app?
thats why i would like to get that app to this box where i have this ROM ...
Maybe somebody can explain this to me pls.....some kodi apps allow you to download movies in a usb pendrive instead of streaming them. However when I select to download in a pendrive and choose the respective destination folder, the movie won't be saved in the external usb. Can you help me pls? Do I need to choose something from the SuperUser app? Thanks.
I´ve just got my new Mini m8s ii and I want to flash this custom rom and I tried, but something went wrong. This are the steps I made:
1) Download the .zip file and extract it onto a blank and formatted (as FAT32) usb stick and put in in the usb right beside the power connection.
2) Put my m8s into recovery mode using toothpick (I even try with an boot-to-recovery app from google play)
3) Try to install my update.zip file from ext->udisk but all I got is a faulty message as my attached picture said. What am I doing wrong?You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by ice cube; 07 March 2017, 13:05.
Originally posted by ice cube View PostI´ve just got my new Mini m8s ii and I want to flash this custom rom and I tried, but something went wrong. This are the steps I made:
This will reboot into recovery without issues I think
this is the way it worked for me
Originally posted by LostEchoes View Post
Install the Terminal app from Play store and type: reboot update
There are currently 2483 users online. 1 members and 2482 guests.
