To All:
Very low interest for 9377 chip rom, but when i was busy i read so many request
Anyway HERE is the Final Test2 not for 9377 chipset, a totally rebased rom, framework changed and revised, many glitches solved, has also a rgb fix(for philips and sony old tv) inside setting (but if you activate it you need to unplug and replug hdmi cable).
Let me know.
Sorry but get ERROR ---> [0x30702004]Uboot/Temprature Testting/Get result/Out of range
Whats happen?
Markus
EDIT: Back on Backup!Last edited by MasterBoy71; 30 March 2017, 16:18.
Originally posted by MasterBoy71 View PostSorry but get ERROR ---> [0x30702004]Uboot/Temprature Testting/Get result/Out of range
Whats happen?
Markus
anyway, i don't know it has been tested on three device until now, no problem of this kind.
I found a result googling and happened to your same device:
"Its the driver, uninstall burn tool. Keep device plugged in go to control panel. Right click on usb device (It will most likely have yellow sign on it) remove it un plug device. Download usb burn tool 2.7 one pc reboots run install program for usb burn tool 2.7. Open tool once drivers finished installing then select rom click Start now your ready to connect device into inside usb port. Should work now."
Or try (i never tested it) : BootcardMaker v2.0.0.2Last edited by Xannytech; 30 March 2017, 17:10.
Originally posted by Xannytech View Post
reply me in pm about private testing...
just let me point out that I used Amlogic Burn_Card_Maker v2.0.2 to burn your TestBeforeFinal1 rom to a SD card and it worked just fine on my Mini M8S II a few days ago.
Originally posted by LostEchoes View Post
Xannytech,
http://chinagadgetsreviews.com/downl...er-v2-0-2.html
Let me know.
There are currently 2695 users online. 1 members and 2694 guests.
