Originally posted by realzed2001 View Posti am using my x96 tv box with this mod final test 2. ir remote can not start box on boot. ir remote working on android starts. Now i can use ir remote and shutdown but cannot start on close. i unplug charge and plug to run . how can i fix
Foto: https://drive.google.com/open?id=0B0...m41TG41eXlFSTQ
Originally posted by pyzha View Post
Ок. Аnd for the Nexbox a95x 1/8gb last revision?
Foto: https://drive.google.com/open?id=0B0...m41TG41eXlFSTQit's the same. The purpose of that file is to give the user the ability to flash back original fw
Originally posted by Xannytech View Post
it's a big fatigue to click the link i provided?it's the same. The purpose of that file is to give the user the ability to flash back original fw
I already tried to flash my a95x 1/8 with this firmware and got a brick. The problem is that a new revision of the board and memory is going on in the new a95x 1/8. And all the previous here on the forum custom firmware make a brick. Need a new firmware for this particular revision of the board., anyway, if you can provide me a link to your right fw i can compile a zip to be flashed with twrp for your box.
Happy Easter
https://mega.nz/#!o4B2xTTT!EY0XxsxRO...yEYqhs8p4fHOhM here is the link for his box. I have the same one. I would like to have a zip version of this particular firmware as well if possible. Thank you so much.
it depends on what you choose in that menu...
I have some apps from the same provider that don't fill completely the screen. The image is shrunk to save the navbar line. The squarehome applications drawer has a grey bar at the bottom of the screen too. I need to add to build.prop "qemu.hw.mainkeys=1" to get rid of the navbar and get the full screen on these apps. That was fixed when you modded the framework in xtmod_2.3beta4. If I do that I don't have access to the navbar power button.
Thanks for your work.
Sorry, but without that information i can't guess nor i can't follow any new mainboard that comes out (that is not my work), anyway, if you can provide me a link to your right fw i can compile a zip to be flashed with twrp for your box.
Happy Easter
With the help of her, I saved my box from brick. I'll be grateful to you if you make a firmware with a working autoframerate and amcodec in SPMC.
Originally posted by Dan31 View Post
Yea, it's not, it's the launcher. What about the menu button, can i program it for example when i press scroll on my mouse ?
There are currently 2352 users online. 0 members and 2352 guests.
