Originally posted by Xannytech View Post
it depends on what you choose in that menu...
What we need is a way to set the default behaviour of the ON/OFF button of the remote control, just like you had it (in the settings) at your previous ROMs.
Is there a way to do this with the new final ROM ?
Thanks in advance.
Originally posted by LostEchoes View Post
Xannytech, If I understand right what we choose on that menu is applied at that time, each time we choose it. So, if we choose Suspend the box will Suspend, if we choose Reboot it reboot, etc.
Thanks in advance.
no if you choose suspend the box will supend until you change your setting again, i worked hard on that framework, and on my box work like this, obviously i used a semi-ready framework from a MXIII II Rom
Another slight change I noticed on this ROM is how HDMI-CEC works.
I have one remote control for my TV and TV Box. One button is the ON-OFF for the Box and another is the ON-OFF for the TV.
I'm always using HDMI-CEC so that when I turn on the BOX, the TV also turns ON (via the HDMI-CEC function). When I I want to turn off both of them, I just turn OFF the TV, and the box turns off, too, by itself (via the HDMI-CEC function).
So this time, if I have HDMI-CEC self adaption set on ON, the box turns on by itself ! I found my box being turned on by itself even after It seemed to turn off.
I solved this by setting the HDMI-CEC self adapation to OFF.
At your previous roms, I had the HDMI-CEC self adaptation set to ON, without any issues.
I will keep observing this and will give you feedback if needed. So far, by setting HDMI-CEC self adaptation to OFF in this rom, everything seems ok.
Thanks again !
Oh I see. So whatever we choose is then set as the default behaviour until we change it. That's brilliant !
Thanks again !
Originally posted by rajawaqas View Post
I downloaded complete 100 percent and this Rom is in winrar after extraction I M able to install in nexbox andriod box...I have real debrid account where I downloaded this romand reinstalled my personal.
Could be that Google Webview causes sometimes that issue, but if i can't reproduce it, i cannot shot in the space a fix
Anyway mate, let me know about that problem about google play if is solved, because i cannot reproduce the issue myself after 3 tests without problem i gave upand reinstalled my personal.
Hello Xannytech,
thank you for your rom.
Tanix TX5 Pro, my report : i'm not an expert, just would like to help. sorry if it seems naive
- blutooth OK
- WIFI (chip 6255) OK
- navigationbar and powerkey management disapeared from parameters
- understood that power management can be set through navigationbar
- don't known how to get the navigationbar : in SquareHome options "hide navigationbar" is not checked. did not find an option to display the navigationbar.
- sometimes, the left part of the statusbar disapears after about one second : usb icon disapears but hour + wifi + bluetooth icons still there
- did not find directory remote in system/media : used remote.conf from your beta
- remote can shut down the box, but can not wake it again : need to AC off/on
- when box shut down, the hard drives are not shut down : need AC off.
- netflix OK
- smpc : passthrough OK but DTS does not work : need to activate Dolby translation, DTS appears as Dolby to my home cinema and works perfectly.
- dark scenes are no more too dark.
Originally posted by Jraf View Post- sometimes, the left part of the statusbar disapears after about one second : usb icon disapears but hour + wifi + bluetooth icons still there
Originally posted by Jraf View Post- did not find directory remote in system/media : used remote.conf from your beta
About Hardrives, mine are switched off, normally, but someone time ago reported a similar thing, dunno why, if i can reproduce i can fix, if not... no idea.
Thanks for your report
My installation experience with this wonderful ROM. (many thanks Xannytech!!)
After my first installation i had the "Unfortunately, Google play services has stopped" error.
I tried to reinstall the ROM. But the error kept coming back.
After a view re-installs I pulled out my LAN cable. Connected trough WIFI and suddenly i could logon my google account.
Maybe this will help someone else.
Originally posted by futureline View PostMy installation experience with this wonderful ROM. (many thanks Xannytech!!)
Anyway another solution is use this APKLast edited by Xannytech; 13 April 2017, 19:12.
I flashed my box and it's all working great, thanks Xanny.
I'm using the wetek classic launcher, it's simple and it looks great, however i'm using a wireless mouse so i have to click apps twice to run it, first it selects an app and then runs it. Any idea i can run apps with just one click. Also this happens in settings. With the stock launcher it's working normal. And how press the menu button with a mouse ?
Originally posted by Dan31 View PostI flashed my box and it's all working great, thanks Xanny.
There are currently 2291 users online. 0 members and 2291 guests.
