Originally posted by Kuno View Post
Yes, copy it over to an sd card with your mac :PI am a complete noob when it comes to android and android TV boxes.
Originally posted by zelder View Post
My new Macbook Pro only has 4 USB type c-ports lol. So much for "pro". But is that how easy it is? I have the stock firmware. Do I only need to transfer it to a SD card and reboot? Is that it?I am a complete noob when it comes to android and android TV boxes.
A little more involved. I don't believe the boot card maker is available for mac, so you will need to bootcamp your mac. So grab a windows 10 iso, as a legit version will still work with no key, and go to town. Grab a USB-C Type C/USB 3.1/Micro USB/OTG TF Micro SD Card Reader from **** and you are pretty much set.
Hi, first I would like to say thanks to the author of this rom, it's really nice to have a community supported firmware. However, there is one thing that bugs me. Prior to installing the rom I played with device while there was still original firmware on it, and I also had LibreElec on a separate SD card. After installing the rom I cannot access LibreELEC. I did not mind making another card from the beginning, but I cannot boot from the SD card. Standard procedure to hold reset button to boot from SD card does not work. It seems like the reset button inside AV port doesn't work any more, and device cannot boot from the card, which is necessary in order to run LibreELEC. I also tried usb ports using card reader, but so far nothing works. Does anybody knows if there is any solution to this?
Originally posted by tuzlak View PostHi, first I would like to say thanks to the author of this rom, it's really nice to have a community supported firmware. However, there is one thing that bugs me. Prior to installing the rom I played with device while there was still original firmware on it, and I also had LibreElec on a separate SD card. After installing the rom I cannot access LibreELEC. I did not mind making another card from the beginning, but I cannot boot from the SD card. Standard procedure to hold reset button to boot from SD card does not work. It seems like the reset button inside AV port doesn't work any more, and device cannot boot from the card, which is necessary in order to run LibreELEC. I also tried usb ports using card reader, but so far nothing works. Does anybody knows if there is any solution to this?
Originally posted by blyx21 View PostIm having some laggy playing mkv movies in local drive. I use mx and vlc both lags when playing mkv. Anyone also having this?
Another thing not working on my device is bluetooth, 2g/8g A95X from gearbest, and I did not see anything in the OP saying that bluetooth is not working. I know there is plenty of different chip versions and perhaps manufacturer switched to a unsupported one in the meantime, but it would be nice to have a working bluetooth since there are only two usb ports present on the board.
Power buton would still be nice to have operational, but bluetooth imho is more important. I read trough the thread and I think I remember somebody said there was some solution where one can copy bluetooth files from original rom. Anyone have a working blujetooth that way?
I just tested, and can't see any problem with usb drive, don't know if network drive works though.
Originally posted by tuzlak View PostI think it's 6330.
Edit: It seems it's 8723 actually, and perhaps that's the reason why bluetooth is not working.
Thats a newer one. If BT not workinf probably your wifi not working also. Are you sure its 8723? Try to open the box and see the wifi model inside
And 5 min later, yep, there is rtl8723bs inside, and wifi works just fine.
There are currently 1910 users online. 1 members and 1909 guests.
