Originally posted by realzed2001 View Postnow loaded x96 to 2.7 vers. but not working wifi and only root+playstore installed naked only can you check this? thank you
What does it mean: "root+playstore installed naked" ?
Originally posted by Xannytech View Post
Sorry but i do not understand what are you saying, X96 ok have you downloaded the correct version for your wifi chip? XTMOD EX P (v 2.7) for TvBoxes with wifi chipset : AP62X2, AP4354, AP4356, AP6212, AP6212A, AP6255, AP6335, AP43458, AP6330
ÂÂ*i will download again this link and try again thank youÂ*
tested: working very well wifi and no more not respongding error on any app using. More fast thanksLast edited by realzed2001; 17 May 2017, 22:31.
Probably i'll post soon a new experimental version (it means i need to experiment something) there is new TWRP updated to 3.1.0-0 some little fix, and some work on Widevine...
So probably i'll need some testing by users that use Netflix, and whom got some erroneous system memory report. If someone is interested do test it with me let me know.
But i need particularly to test this two things.Last edited by Xannytech; 18 May 2017, 20:49.
Originally posted by Xannytech View PostProbably i'll post soon a new experimental version (it means i need to experiment something) there is new TWRP updated to 3.1.0-0 some little fix, and some work on Widevine...
Originally posted by bajann View Post
im here i can test (Netflix).What about memory??
Reason I'm asking is because currently the Magisk installer doesn't work properly because it can't uncompress the initramfs properly - manually uncompressing it works, tough, so in order to get Magisk working on the previous version I had to rewrite the boot partition.
Originally posted by Znuff View Post
If you're going to work on the ROM, can you please make sure the initramfs image works properly with Magisk? (ie: you can install Magisk on it)
I know that everyone has a mod that want, but i have to deploy rom stable and working for everyone, so sometimes i must do choice about stability.
i could, but step by step... or bugfixing will become a nightmare.
For some reasons, I am assuming that you gzipped the ramdisk.cpio image yourself, with gzip -9?
There are currently 1541 users online. 1 members and 1540 guests.
