I would just send it back to wherever you bought it from.
I read the thread and nobody says xannytech ROM has caused any problems? Just faulty/cheap clone boxes. The problem is they are incompatible with this and any other previous ROM for m8s mini ii. My advice would have been to copy the WiFi drivers and remote.conf to a usb before doing any updates.
I think asking politely is not a issue. Xanny knows we watch. But asking and thinking you may get a response is normal. Keep on topic.
We like that Xanny here. I know its alot of posts because it popular most questions asked over and over so take some time and read the thread. Be surprised how much usefull info is in itMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Adding a donation never hurts your cause with any dev. But giving any donation is just that. May or may not fix your wanted fix. Its up to them if they have time or wish to. So dont be upset if you do send some cash and it still doesnt get fixed... Hes fixed a ton of stuff already thats made your device better.
Thanks XannyMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by azizlaite View PostHi. I have a Mini M8S II that i have running xannytech rom, and i can update it anytime.
Now i have bought another one, but i cant update it. Neither using the sd card method (says it cant mount the sd card or something like that, in the recovery), nor the burning tool.
Has anyone managed to install the rom, on a new box lately? If so, any tips?
best regards,
azizlaite
EDIT: Several other users are reporting bricked boxes after trying to update the rom (http://freaktab.com/forum/tv-player-...-with-nand-pin). Seems there's something different with the new batch of boxes. So caution is advised (and help, very much aprecciated).
Anyway next time i update the first page i will post a warning.
Originally posted by jonscravit View PostPliss add RTL8723bs bluetooth suport
Without any help from users i cannot do nothing and i prefer to avoid any problem selling promises.
Then the biggest problem is the language, many users are asking for support but do not write in english and mostly uses Google translate... and it's a mess to communicate.
Anyway simply remember i cannot give you a "universal" rom working on all the device.
Actually i'm working on a ATV rom i'ts almost ready.
Originally posted by Xannytech View Post
Very useful , but from what i see (mainborad photos) it's a totally different device now... They are totally crazy calling it with the same name.
Best regards.
Thank you. BTW I'm willing to help if you have the time to try and make your ROM compatible with the new boxes.
Best regards.
Anyway can you tell me which device are you using?
Can you then, link me a original FW in which Bt work for your device? I need eventually for comparative reason.
Originally posted by Zhite View Post
I mean the Zip version....
I have a X96 , i really want to flash this rom
*Edited : Sorry... I get it
OK so with my rom fresh installed, install THIS zip file through twrp and let me know. It's for 8723 chipset, a test to add BT drivers.
Had to short the pins and flash the rom in the other topic.
If it helps, I do have a new box, intact.
Tried again and same result. After flashing the rom, the box doesn't even boot up anymore, so I can't access the recovery to flash the zip file.
i checked myself you cannot flash my rom because your new box uses a totally new incompatible mainboard...
So why you offered me help to test my fix for 9723 Bt chip if my rom cannot work on your box?
Probably you would like to have a custom rom that works on your device... i know how is difficult to understand... But i do not own your hardware, i not a magician, how can compile a rom or found a solution without knowing anything? No firmware, no Hardware, nothing?
I hope the seller that earned your money could help. I do not work for them.Last edited by Xannytech; 11 August 2017, 14:32.
There are currently 2399 users online. 0 members and 2399 guests.
