Hello Xannytech,
thank you for your rom.
Tanix TX5 Pro, rom version 2.7bis, no SD card, 2 hard drives 2.5', Xiaomi portable mouse, no modifications, my report :
- new boot logo : OK
- SU asked to be updated, made : OK
- blutooth : OK
- WIFI (chip 6255) : OK
- directory remote in system/media : OK
- remote can shut down the box, but can not wake it again : need to AC off/on
- when box shut down, the hard drives are not shut down : need AC off.
- netflix : NO, says "not compatible"
- smpc : passthrough OK but DTS does not work : need to activate Dolby translation, DTS appears as Dolby to my home cinema and works perfectly.
- dark scenes : OK
have a nice day
- netflix : NO, says "not compatible"mine works... i have to revert the fix? can someone else confirm this issue?
About on/off i can do nothing it's a bootloader problem and the fix i thought works random so i give up for now.
About hdd power dunno mine poweroff correctly, but someone reported same behaviour.
About Su update, i know i prefer the user update to avoid problems.
Originally posted by Xannytech View PostThanks for the report the important and unexpected part is Netflix "not compatible"mine works... i have to revert the fix? can someone else confirm this issue?
i can live with these problems, except the new problem, netflix : i rather prefer it to work. is there something i can do ?
thanks
Originally posted by digitalriver View PostHello, XannyTech. Are your 2.7biz still doesnt support bluetooth for RTL8723BS ? What the differences between 2.7 and 2.7biz?
After the netflix update my fix stopped to work and can cause a problem if you got problem like "unsupported device":
FIX:
open Totalcommander
go to /system/vendor/lib/mediadrm
rename libwvdrmengine.xo in libwvdrmengine.so
reboot
Obviuously then you should edit build.prop bootvideo=0
I apologize but it's not totally my faultbut i'm wise enough to left a way to unfix the fix
: D
There are currently 2982 users online. 0 members and 2982 guests.
