Hello, XannyTech. Can you look at little part of logcat? This is board with rtl8723bs
bluetooth.txt
I will try insert your files from your older post for another man, and I will try insert FIRMWARE(and BLUETOOTH) folderfor my old firmware, and its not help form me. Bluetooth not work (wifi - work)
Originally posted by digitalriver View PostHello, XannyTech. Can you look at little part of logcat? This is board with rtl8723bs
[ATTACH]n645294[/ATTACH]
Originally posted by Dandroid534 View Post
What.are you using for permissions? Try root browser or another app? Give it all permissions and.see if it works, I assume the remote.conf is from stock rom?
Originally posted by Kuno View Post
Yes it is from the stock rom. I have tried 646, and I have also tried the permissions that the file has on the usb stick, where I copied to originally. I haven't gone and given it all permissions yet. I used total commander to copy it to root, as it has root permissions. As I said if I can't get the remote working it's not a big deal, it just would be nice to have a working remote haha. Mouse is more than sufficient for what I need.
Originally posted by Xannytech View Post
I dunno why your remote does not work changing remote.conf right permissions are 644 . Anyway give a look to a cheap but functional arimouse like the one i use Mx3
I could just be my luck with electronicsBut you know I have no issues with your work and am really really happy. Yundoo Y6 is an awesome box, full dual band wifi supported on your rom and bluetooth as well. Just no remote haha. I can send you the remote.conf I have if you want to add it (I know adding yet another unsupported box, right?) I seriously think I am the only person on this board with this box though, so no worries. Thank you kindly again.
Airmouse is annoying as the one I have doesn't have glow in the dark keys haha. I really need to upgrade it
Originally posted by Xannytech View PostWhat?
I went back to stock, confirmed to have a functional bluetooth and than copied the entire factory original "bluetooth" and "lib" folders to disc. I than flash your rom and copied those too to compare with factory firmware. By using "replace and eliminate" method I found out that replacing "bluetooth.default.so" from system/lib/hw with factory version activates bluetooth. Mac address is now present is the system I can turn the bluetooth on and off in settings. However, the box can not discover other devices, nor other devices can see the box. I also tried replacing "libbluetooth_jni.so" because of a slightly different size, but nothing changed. Also, renaming and even deleting "libbt-vendor.so" and "bt_vendor.conf" does not do anything. And that's where I hit the wall.
But, maybe you now might have an idea what's going on. Or I perhaps it's time to give up.
There are currently 2851 users online. 0 members and 2851 guests.
