    Originally posted by Xannytech View Post
    And for the second time [/U]
    OK, Im understand, thank you, XannyTech.
      Hi there,
      After enjoying my mini m8sii for around 1 year, I am about to put it to trash bin because it has stopped working
      But before doing so, i wonder if anything can be done to save it.
      The box boots normally, aplications open and work normally but, after a few minutes, the image freezes and the box stops responding. I then have to reboot the box unplugging and replugging alimentation. And this again..
      I wondered if it's not an overheat issue, so I opened the box and left it open just to test. Same result..
      Do you think, as I do, that my box is dead?
      Thak you for your help!
        Netflix from version 5 (yet in my last rom) is going to check root devices... some problems comes from there... funny, probably i have to work a bit on magisk?
          After the netflix update my fix stopped to work and can cause a problem if you got problem like "unsupported device":
          FIX:
          Obviuously then you should edit build.prop bootvideo=0
          hello,
          did not find bootvideo
          only service.bootvideo=1
          if changed to service.bootvideo=0 :
          - boot logo Xtrom Ex replaced by android
          - dark scenes are too dark.
            Yes this is not a nice thing that they have done. Very user unfriendly if you ask me. Might be time to put a little note to tell people what is going on as more people might start "complaining".
            http://www.androidpolice.com/2017/05...l-working-now/ <-- link to story for people wondering
            With our latest 5.0 release, we now fully rely on the Widevine DRM provided by Google; therefore, many devices that are not Google-certified or have been altered will no longer work with our latest app and those users will no longer see the Netflix app in the Play Store.
            Last edited by Kuno; 14 May 2017, 20:15. Reason: added reason netflix no longer works on app
              Originally posted by Jraf View Post
              hello,
              if you need more brightness edit in /system/etc/int.d 05videobrightness like this:
              #!/system/bin/sh
              echo 10 | tee /sys/class/video/vpp_brightness
              Then reboot, problem solved.
              Jraf use search in this thread it's faster for you
                I think is possible to update the app through apk mirror, i don't know if the app itself will work in next releases.
                  The app that comes with the ROM doesn't work, at least for me - I get "This app is not compatible with your device" http://i.imgur.com/eNeuPCD.jpg and redirects me to download the 4.x one.
                  The 4.x one has no Downloads support: http://i.imgur.com/LG3dXc4.jpg
                  I have even tried to hide it with MagiskHide (after I spent hours to actually install Magisk v12 on this ROM without bricking the box) but to no avail.
                    Znuff, please, read just a little bit the thread HERE anyway you can use APK mirror to download Netflix versions
                      No power off settings(bis) ?I will try later 9377 ROM....tnx xannytech
                      Can yo reupload first version 2.7 ROM(new kernel)?
                        My friend power off from 2.5 are longpressing the power icon in the navigation bar.
                        About 2.7 with the new kernel which version? and why?
                          I do appologize about that, didn't see it at all. Thank you.
                            For ap6212,ap6255 .......version, I have strange issues with power off -power on with remote sometimes is OK but sometimes I can't turn on device (something about CeC or maybe is becouse mine USB flas in I will try without usb )......I'm sure something is mising .Thanx again ,sry on mine bad eng...
                              Hello Xannytech,
                              I have installed the firmware on a TX5 Pro. Could you please help me regarding a Hungarian TV channels website called mediaklikk.hu
                              It doesn't matter what browser I had installed from the play store (Mozilla, Opera etc.) when I try to access mediaklikk.hu it gets stuck at the start page.
                              Is there a flash player or add-on that I'm missing to access the content of the website?
                              Regards
                                Originally posted by rozsalyib View Post
                                Hello Xannytech,
                                Regards
                                Disable AdAway.
