- Rebased Firmware now is from a MX3 II Rom V112M0 dated 3/6/2017, before was a mixed one from Mini M8SII and MX3 II;
- TWRP Updated 3.1.0.0;
- Fixed so many little bugs around that you can't imagine;
- Removed some workaround after bugfixing;
- Pre-setted launcher, 'cause i saw so many user incapable of click a single setting (
.gif)
- Netflix problem with bootvideo fixed (but you can get same problem if you play Hi-Res video with another app, it's a Netflix app problem, not ROM related, eventually just reboot and it works as it should);
- Updated SPMC to 16.7.0;
- Updated pratically all the apps and apks in rom;
- Added Gmail, and GCalendar by default;
- Updated hostfile for adblocking;
- Something that for sure forgot to write down
XTMOD 2.8 for TvBoxes with wifi chipset : AP62X2, AP4354, AP4356, AP6212, AP6212A, AP6255, AP6335, AP43458, AP6330, 8188XX, 8189XX, 8192XX, 8723XX, 8812XX
(it's a 7zip file to be unpacked and then flashed with Amlogic_USB_burning_tool_2.0.8 or BootcardMaker v2.0.0.2 if you want to use sd method (guide)
If you have a 9377 wifi chip device flash the image, then before booting the rom, go to recovery and install this file:
- Wifi 9377 TWRP ZIP
Enjoy
