Originally posted by jonscravit View Post
HI
Thank you for the work you do.
Here in Brazil is selling many TV BOX yundoo Y6
2gb ram and 8gb internal model ..
I can be your betatest, and I will indicate donation to you for the work in this ROM (I will donate), I will make up video showing your ROM.
This ROM has Bug gamepad, on dragonrise usb circle open music app, xbox Dpad lef open power menu, on PS3 gamepad L3 open music app ..
I installed this app and tweaks for stream, lan and internet was very fast from what is already
Https://play.google.com/store/apps/d...6.lspeed&hl=en
Here the link of ROm yundoo, model 2gb / 8gb use RTL8723 wifi / bluetooth
Http://chinagadgetsreviews.com/downl...y6-tv-box.html
I'm searching for users with 8723 chipset to fix, if is really broken, Bluetooth.
Donations are welcome, but honestly i will try to help you (if it's possible) also without them... in real life i'm not so cheap
Originally posted by Xannytech View PostNot easy... just do some tests try to decompile your stock rom then delete system folder and put instead mine, recompile, if it boot, should lack of some script and my kernel, but it's a start point.
I doubt it will boot but if you want to experiment something, you should try.
Code:[21.128760@3] fs_mgr: check_fs(): unmount(/data) succeeded [21.260260@2] audit: type=1400 audit(1420070424.640:4): avc: denied { execute } for pid=3635 comm="init" name="e2fsck" dev="mmcblk0p13" ino=289 scontext=u:r:init:s0 tcontext=u:object_r:unlabeled:s0 tclass=file permissive=0 [21.279213@2] fs_mgr: Not running /system/bin/e2fsck on /dev/block/data (executable not in system image)
Code:[20.818099@1] fs_mgr: check_fs(): unmount(/data) succeeded [20.818924@1] fs_mgr: Running /system/bin/e2fsck on /dev/block/data [20.894390@1] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [20.894390@1] [20.895128@1] e2fsck: /dev/block/data: clean, 11/321920 files, 42883/1287168 blocks
Originally posted by Igorbambus View PostProblem must be in CustomizationTool, packing system image.
Originally posted by Xannytech View PostNo, the problem is that you should know how you emmc is partitioned, Customization tool works on standard partitioning, probably your device (just guessing) has different memory partitions and this will cause a mess. If you ask me why... honestly dunno it's a manufacturer fault/choice.
both logs same stock rom
https://pastebin.com/Ax5RL0z2 - After only repack with unpack system not working
https://pastebin.com/feb2SH1y - Repack without unpacking system working
first diff in bootlog
Code:[ 1.409805@1] Freeing initrd memory: 900K (ffffffc033dd7000 - ffffffc033eb8000) - not working [ 1.409237@1] Freeing initrd memory: 900K (ffffffc033dd6000 - ffffffc033eb7000) - working
Ok I check boot log and find this diff
Originally posted by Xannytech View PostAnyway after three days 0 users gave me a report for my fix for 8723Bt ... though 24 downloads
I hope this explain once and for all why i cannot provide any help for hardware that i do not own.
Easy and simple.
installed bluetooth fix 8723 and did not work .. the error in the setting when I turn on bluetooth ...
But I did not have time to clear the box to see if it works, I'll reset it until tomorrow ..
But I opened my box and saw that chip is RTL8723bs
sorry for being late
Trying to update to the latest version. I tried the burn card method and it doesn't seem to install. Also tried install the img via twrp but get a message that file is too large or something like that. Any thoughts anyone
Is there any reason after flashing the previous version the recover bottom would no longer work.
CheersLast edited by Tango One; 17 August 2017, 19:28.
There are currently 4687 users online. 0 members and 4687 guests.
