Hi Xannytech, any chances on implementing https://github.com/northox/ov-secure...e_client_api.h on the rom? An app here is asking for OTZ TEEC support. Thanks!
Originally posted by kreator View PostHi Xannytech, any chances on implementing https://github.com/northox/ov-secure...e_client_api.h on the rom? An app here is asking for OTZ TEEC support. Thanks!you don't know but it's a very big work to add these lines and so much testing has to be done just for an app?... i actually think i will not do that.
Then i do not understand why an app needs non standard hooks in kernel, it's insane.
By the way, any chances you'll make this rom work on the other machine I mentioned a while ago? On this post:
Thanks again, congrats on the awesome work!
Understand completely, thanks anyway hehe.
http://freaktab.com/forum/tv-player-...481#post627481
Thanks again, congrats on the awesome work!i forgot to check your rom... sorry i was very busy.
Anyway T95x... probably has a new motherboard from nexbox? Any custom Rom works on your device?
On my thread on XDA more that a user reported working with just bluetooth unfunctional 8723x chipset i suppose.
If is simple to fix like D4X16 motherboard no problem, but i need some help from users.
Some other users with the same box T95X ?
From all roms I tried, only the one I posted worked. From looking at the motherboard I can't figure out which one is it, I'll install cpuid and take a look.
Anything you need just ask! Thanks!!!
*Update: CPU-X says the mobo is an Amlogic P212
No problems!!
So no custom rom can work on your motherboard, i can assure it's a new Nexbox new model motherboard pratically unflashable with anything than a stock rom.
Now we can do an experiment but your device will be probably (not sure) bricked again...
If you would like to try tomorrow i can decompile the rom you linked and recompile 1 rom just for test, but be ready to nand resetting your device, because i did some tests time ago and i failed
It's what the program read from Buld.prop
But sure, now that I know the pins... hehe
Maybe a TWRP backup would help too. Didnt have one the first time.
There are currently 2434 users online. 0 members and 2434 guests.
