Originally posted by Xannytech View PostFor the users that got Google Play Bug i prepared a zip to be flashed trough twrp.
I tested myself but let me know if all it's ok
XTMOD3_MARKETFIX
Hello
I'm greenbut I want to learn how to install this great ROM
I have NEXBOX A95X 2/16 with stock firmware.
Do follow this guide I am able to install this software? http://androidpcreview.com/how-to-us...firmware/3749/
Do I have to install TWRP before installing this software? If yes please send me tutorial
And dont forget to flash the fix for the google playstore error again in the first page
XTMOD3_MARKETFIX
Originally posted by ssarava9 View PostAfter flashing marketfix zip my nexbox gets into TWRP loop, i tried multiple times to reboot still the same issue, anyone have suggestions please advise
HERE
Originally posted by makavelio View PostWill you be working on a Android 7 rom for this box? Thank you for this great rom
1. Remotes are coded in a different way so probably they will not work correctly;
2. Once installed 7.1.2 rom in some device, like Mini M8Sii, MXIII II (for ex.), could be difficult to go back to 6.01 in a easy way;
3. XPOSED actually does not work on 7.1.2;
4. TWRP i need to recompile it for 7.1.2.
Which are the advantages using 7.1.2 for the final user : NONE
So i'm not sure i will ever post one.Last edited by Xannytech; 30 October 2017, 17:58.
Hello
After installing this software according to the guide and patches to the play store i cant boot System
TvBox only turn on in TWRP mode. Please help me
I downloaded and installed this file by TWRP but did not help ;(Last edited by Scrimerr; 30 October 2017, 23:30.
Which is your device (please i cannot guess)?
Which version of my rom have you installed (means normal or nexbox bootloader one)?
I installed rom from this link https://mega.nz/#!LF5hTSLR!KrNP8Z0WB...kwzD4H21Ty_DK4 by the guide http://androidpcreview.com/how-to-us...firmware/3749/
Originally posted by Scrimerr View PostI have NEXBOX A95X 2/16 with stock firmware.
The only side effect you can have using mine, is the power on on remote not functional.
Sorry but i can't help you with the other rom because i don't know what really happened there, i think is something regarding memory locations that broken TWRP recovery, but i do not own a nexbox and i did not compiled that rom.
There are currently 1982 users online. 0 members and 1982 guests.
