Load P212 twrp in a seperate sd card and reboot to SD and reboot from twrp to systems and now remove the twrp sd card and insert libreelec sd, try rebooting to internal, i tried this and it worked
Originally posted by ssarava9 View Post
Try this:
ssarava9 i read so many problems... probably due to your recompilation, try to recompile in this way:
1. decompile just Level1 so just first 4 voices on Amlogic Customization tool;
2. overwrite bootloader stuffs with the one you used;
3. overwrite recovery with the recovery you downloaded (it's the same, but the program will recaclulate the partitons);
4. recompile
Originally posted by Xannytech View Postssarava9 i read so many problems... probably due to your recompilation, try to recompile in this way:
4. recompile
ok i undestand something very wrong is in nexbox bootloader (probably it overwrite some recovery locations), so the only way to solve that issue for Nexbox users is to try to solve market crash installing another market through aptoide (yet installed in rom), eventually reinstall also Google play service in the same way.Last edited by Xannytech; 05 November 2017, 16:20.
Originally posted by Xannytech View Postok i undestand something very wrong is in nexboxbootoloader (probably overwrite some recovery locations), so the only way to solve that issue for Nexbox users is to try to solve market crash installing another market through aptoide (yet installed in rom), eventually reinstall also Google play service in the same way.
Originally posted by Xannytech View Postok i undestand something very wrong is in nexbox bootloader (probably it overwrite some recovery locations), so the only way to solve that issue for Nexbox users is to try to solve market crash installing another market through aptoide (yet installed in rom), eventually reinstall also Google play service in the same way.
Originally posted by rajawaqas View Post
Kindly expand that topic I can’t understand because I m beginner.which application I install through aptiod?
Also because you yet solved your problem as stated on your previous message: "I'm using your standard rom version and I also installed updated version of google play store from apkmirror.com 8.3.42 version after that stop google play error vanished."
Sometimes i do not really understand what you mean...
?i'm sorry i can't explain better a so simple task: install google play and google play services from aptoide.
Hi Xannytech....
I drop by here to say thank you for this great work. It works very stable on my x96 2/16 version.
As far as I can report:
I used your original ROM posted in the first post. Flashing with SD Card Method, and replace the remote conf as suggested.
At first, the power button of remote can not power on the unit. But the button '2" does the trick, not so annoying, I can live with that.
But if there is a simple modification to remote conf that can fix this, I will be glad to try.
DTS passthrough was a problem in KODI 17. But I think it is a problem in KODI 17. I see a lot of complain on that.
So I removed that 17.5 and replace it with 16.1 Jarvis because I really need that DTS Passthrough.
At first, Jarvis gave me blank green screen, but I managed to fix it by changing the refresh rate in the display resolution setting, Set to 1080 50Hz.
SPMC works out of the box, no problem at all. All DD and DTS passthrough works just fine. I use SPDIF optic cable to connect to my receiver.
I use MK220 wireless keyboard mouse without any problems. 'Enter key" works as it is intended to.
The only problem is that I have to hold 'alt+tab' key to swithch between apps. i expect that I dont need to keep holding those keys, just like when I click the 'recent Apps' Icon.
Not so annoying, I can always use the Home button and then click the 'recent Apps'.
i just hope that the next release will allow me/us to assign keyboard shortcut to home screen apps to run.
I use ORICO 9548u3, 4 bays hard drive enclosure to store 8TB of my movie collection, no problem so far.
Again, Thank You.
Javen
Is there a way i can create an img file from my current firmware which has nexbox bootloader and marketfix applied, i'm running my nexbox with its bootloader and no issues , so if i can pack the firmware as a zip maybe its easy for someone to use it as its all applied already.
In the mean time i will try your suggestion to overwrite the recovery partition and test it out
Hi Xannytech,
No it's a little bit complicated from a installed rom, you should do some copy of the partitions with "dd" linux command, but the problem is in bootloader not there.
There are currently 3649 users online. 0 members and 3649 guests.
