Originally posted by Xannytech View Post
Originally posted by ssarava9 View Post
Yes my recompiled ROM will work with nexbox on power on and off using remote but i too have the problem of TWRP getting into the loop, please try p212 twrp from " https://1drv.ms/u/s!AoqocX31ecnXgZwNCL9pqWEsLDw_hg " and load it using microsd card, flash Xannytech marketfix, you should be good then
ok let me know so i can post the fix in First pagethanks again.
Do I copy ten file from you on SD and install it via TWRP "Install"?
Thanks for sharing this rom, Xannytech
I just got this rom run smoothly on Vontar X96 (2/16) with USB Burning Tool method.
Though the power button on standard remote could not works to make it on, but I just found out that "2' button can replace that power on function.
Playstore runs well, except, I couldn't manage to (re)Install Google Chrome that I accidentally uninstalled it before. Deleting Playstore & Google Play Services data & cache, & deleting Google account then re-add it, neither can solved it.
But.. it not a big problem because I still can install other browser like Via Browser, etc.
And one other thing... The navigation buttons on the squarehome2 launcher not showing up, I only see the nav bar, though they're not set (no check mark) to hide on the setting menu.
But then again.. this is also not a big problem. The substitute navigation functions are all in the wireless keyboard that we can use.
Please consider this as a report, not as a complain.
Thx again, Xannytech.Last edited by KayuTimur; 11-01-2017, 17:10.
First of all thanks for great rom. I have problem regarding WiFi dropping in Youtube in xanny’s Rom but stable in default nexbox S905X rom never drop out..I copy ap6330 WiFi drivers from default forware and replaced xanny’s great rom but WiFi is not stable in Youtube and error made in every 6 to 10 minuted cannot connect server (WiFi drop out)when I installed nexbox rom then no disconnection and drop out .. kindly help me because I want to use xanny’s great rom. I have nexbox S905X 1g 8g with moddified WiFi external antenna.
Hi all,
I bought this about 6 months ago, still in the box unopened:
"Nexbox A95x" S905X 2GB / 16GB
Model: A95X-B7N
My Tronsmart S89 died so I'm finally going to open this one.
Reading the OP, this appears to be the correct ROM to flash:
- XTMOD 3.0 for NexBox A95x 2/16 (should work also for 1/8) repacked by ssarava9 with remote power functional.
(in message #1887 he posted a description of what he did to eventually try yourself)
Just to verify, is that correct?
AND, is there ANY way to make an backup of the initial "untouched" state of the brand new box as it is, for example by somehow booting off of a "live" SDCARD with TWRP and saving a backup to that SDCARD, in case I want to later start "fresh", or something else.
If so, any links/guides to doing so is greatly appreciated.
This Tutorial help me when i have "TWRP LOOP" https://chinagadgetsreviews.com/down...er-v2-0-2.html
Anybody knows how to stay "YouTube TV" app in memory ??
Originally posted by rajawaqas View PostFirst of all thanks for great rom. I have problem regarding WiFi dropping in Youtube in xanny’s Rom but stable in default nexbox S905X rom never drop out..I copy ap6330 WiFi drivers from default forware and replaced xanny’s great rom but WiFi is not stable in Youtube and error made in every 6 to 10 minuted cannot connect server (WiFi drop out)when I installed nexbox rom then no disconnection and drop out .. kindly help me because I want to use xanny’s great rom. I have nexbox S905X 1g 8g with moddified WiFi external antenna.
Power button issue it's normal on X96.
Navbar it's just hidden, but you need probably a mouse o an airmouse to show it, simply swipe from the bottom of the screen to up with a mouse (click and up keeping clicked).
Navbar icons problem solved. Thank you.
About Chrome, it does exist on playstore, but everytime I try to install it (on playstore or aptoide), it just won't installed (after done downloading)... error -504.
& no positive result with manually install chrome apk (from apk mirror, etc)
The strange thing is, I don't have problem installing any other apps
I changed nothing regarding wifi drivers in this release, so it's weird... from which version you got this issue?
I am using xtmod 3.0 standard edition currently now. When I watch long duration videos in YouTube (andriod tv Version: 1.3.11) then WiFi drop occurs ( cannot connect server) that’s why i again installed default nexbox firmware for testing purpose only and WiFi stable in default firmware. This type of issue also mention in post #1656....I have also xtrom 2.7 and 28 and i installed and check these versions and this problem is also present in these just only in Youtube only 1080p videos any other application runs smoothly through WiFi. i.e. Sony live app (720p) etc runs smoothly in yours great rom. All over ur custom rom is great and amazingly fast you are great developer alive God Bless you.
Originally posted by rajawaqas View PostThis is off topic but I need ur suggestion. How to enable amcodec in spmc in default nexbox’s rom because in expert mode there is no amcode setting visible in setting but in ur rom amcodef setting is present there.Sorry for bad EnglishLast edited by Xannytech; 11-02-2017, 12:34.
There are currently 1243 users online. 21 members and 1222 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
