Anyway if you're using MY rom there is a program installed it's a reboot app, click on it and you can choose to reboot to recovery.
Originally posted by Xannytech View Post
For give you a correct reply you have to give me an important information: which device are you using? Normally the problematic one are just Nexbox, so i suppose you have one?
Impressive deduction.. yes, sorry Nexbox A95X and yes your rom does have that great feature... now I can't flash the Image cos it says its too big for partition but that is NOT your fault or problem, Thanks for the help!
Originally posted by EagleEyeXZ View PostGreat rom.... only thing if i use frequency switch addon in kodi 17 i get a green screen. The picture is ok without switching but would be great with switching
My rom has AutoFrameRate yet working without any addon with SPMC or MxPlayer or any good programmed player, we discussed a lot about it.
I don't know nothing about your hardware and your TV (probably where the problem sit), so how can i help you?
Originally posted by EagleEyeXZ View PostOk i use kodi 17 official with Android Media Codec not amcodec. So i thought i use frequency switch addon to make it happen but then i get a green screen. Maybe switch to SPMC 17 alpha? It has amcodec
what would you do?
Anyway if you like to get problems Kodi 17, kodi 18 alpha or SPMC17 Alpha
I told you nothing related to rom, just user preferences mate.
yes... anyway from the error you got you're trying to flash the wrong file trough TWRP
Any ideas how to flash another rom?
Magendanz said I needed to use the USB burner so I got my USB to USB cable and tried that... It seems that your Rom must have something different on it as no amount of plugging in with USB cable and tooth pick on reset gets the USB burn tool to recognise the box. Likewise with the SD tool. I can use your reboot util to reboot to recovery or bootloader. If I boot to bootloader it just loads the rom. If I boot to recovery (TWRP) then its not recognised in the USB burn tool.
Thanks, I had tried that too and no joy. Oh well... looks like I am stuck on your rom ;-)
There are posts with pictures on this forum as which 2 pins to short.
Originally posted by Jancales View Post
You will have to open your box and short the pins on the eMMC chip to make usb burning tool recognize your device.
I successfully flashed XannyTech rom to my box AceMax G10CX with front LCD display (PCB ver: G9CX-U) 1/8GB.
I used the SD card method.
What did not work in start:
1. Remote
2. Google Play Store
3. LCD display
I updated Google Play Store and Services with newer stable version from Apkmirror.
I changed remote conf with original file from AceMax firmware and from then remote works OK except power button for power on.
In one moment I started to press all the buttons on remote, and guess what - box is turned on
By further testing I succeeded to find way to turn on box.
By pressing in a row next buttons:
1 2 3 Back button
LCD is dead. Is it possible to do something with LCD?
You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by rasplinjac; 05 December 2017, 08:43.
There are currently 2148 users online. 2 members and 2146 guests.
