Originally posted by EagleEyeXZ View Post
Why would you get rid of that? It keeps your device fast and good working
I have a maintenance addon that automatically clears the Kodi cache, but the app cache doesn't need to be cleared each start up.
Originally posted by EagleEyeXZ View Post30 sec of delay... well you can try another rom that doesn't clear trash. There are 2 other roms you can use... i prefer this one. Good luck. Maybe you can turn it off in this rom didnt find it
I didn't say I don't like this rom, in fact I said I like it, I only ask if it is possible to switch it off.
I am not able to make my pc recognize my mini m8s2 in anyway posible!I folowed your tutorial from the link but nothing is hapening when I connect it to my pc.Btw there is no recovery button or should I say a hole on my box, and there is no power button.I power it via cable or via remote when it is already plugged in with power cable.I managed to enter recovery via android app but still nothing as if I never connected anything.Any help would be greatly appriciated!?Thanks in advance
EDIT: I also tried the microsd card way, but when I power up my box it just boots normal way into the OS and ignores my card.
EDIT2: oh man, I forgot to do "reboot update" thing and now update finally started.I am waiting it to finish.
EDIT3: flashed successfullyLast edited by kemkokems; 23 January 2018, 14:36.
I swear these boxes gets on my nerves....was on xtmod 2.3, boot into twrp recovery via quick boot app and now blank screen on startup.
How do I get back without losing all my data as I spent over a year setting it up.
Thank you. My box is A95x 2/16gb.
Anyone success on getting Dolby Atmos or DTS-HD from this firmware ? im using latest firmware and when running kodi 17 there is no sound when i play dolby atmos or DTS HD or DTS-X audio formats, i can read from other firmware forums that they are successful.
I'm using Nexbox A95x S905x 2gb/16gb box
Note: i have no issues when using libreelec but wanted to get from android as well
There are currently 1741 users online. 0 members and 1741 guests.
