Installed newly Test 1. All fine well. Only one issue, that is Youtube get ads although xposed is active and youtube adaways is active. Still get ads. Then I install other rom like Probox 2 Air and stock x96 rom. There i don't get ads on youtube. I don't know what is the reason. Probox 2 Air rom is very good, but I don't get wifi dusto missing wifi driver, maybe. I want to use this rom, but i get ads on youtube. I did tried iYTBP - injected YouTube Background Playback and Patched ad-free YouTube APKs which are working fine on my mobile without ads. But still in this rom I get ads on youtube. What shell I do?
Originally posted by harkamanshivakoti View PostInstalled newly Test 1. All fine well. Only one issue, that is Youtube get ads although xposed is active and youtube adaways is active. Still get ads. Then I install other rom like Probox 2 Air and stock x96 rom. There i don't get ads on youtube. I don't know what is the reason. Probox 2 Air rom is very good, but I don't get wifi dusto missing wifi driver, maybe. I want to use this rom, but i get ads on youtube. I did tried iYTBP - injected YouTube Background Playback and Patched ad-free YouTube APKs which are working fine on my mobile without ads. But still in this rom I get ads on youtube. What shell I do?
Originally posted by damod11 View Posthi guys. will this run on the sunvell t95x 2g/ 16g ? should be fine as it runs on the 2g/ 8g as said in first post. I just want to be sure
it was happening on stock T5X20002 as well. Libreelec from usb was flawless with t5x20002, but now it's crashing with xannyrom.
I'm going to flash t5x20002 backup just to get libreelec again.
Has anybody any idea what's happening with my device ?
Any help would be appreciated.Last edited by damod11; 09 April 2017, 16:43.
Originally posted by Dandroid534 View Post
If you want a good launcher, i recommend the wetek classic launcher, available from aptoide store. F6 to add apps to favourites scrolling bar.
i have x96 2gb ram 16 gb rom and using now final2 img but system ram is 1gb using only how can i fix this?
i used sd card with loading this rooted rom if i use usb work correctly?
any file change to modify system ram amount please help. Thank you for perfect mod.
Which chip or brand usb bluetooth dodge work well?
Hello,
I have the Mini M8s II box, running stock firmware.
As I have trouble with passthrough DTS on Kodi, I want to test this ROM.
I have few questions:
- do I need specific material (USB cable)?
- the UNZIP to SD Rom will do the job?
what is the difference between the 2 methods and why choosing one method vs the other?
- how can I flash back to stock ROM ?
Thanks for your help
moreje
Originally posted by Gilgamesh View Post
ok thanks, I want a launcher that works good with the remote that comes with these boxes, but maybe this launcher that comes with this ROM does work good without air mouse?squares is ok, but gets a bit messy. Wetek launcher is the best imo, i put it on all boxes now.
Xannytech .. Your Custom-ROM is wonderful .. only just my WiFi in the Nexbox A5 (2G-16G) does not work.
I have previously saved an AP6330 folder from system / etc / Wifi and then copied again, as you wrote it in the 1st post.
I also set the permissions with 644 and test times also times with 755.
Unfortunately, the WiFi is not, always comes the 02 at the beginning of the Mac address afterwards only 00x00x00x00 etc.
What is the cause of the WiFi AP6330 not working? Is still missing a * sys file? Or a config file?
Thanks for help .. would like to use WiFi further.
Originally posted by Xannytech View Post
ZIP Version (unzip the content in a empty sd card insert and reboot in recovery with toothpick metod to install)
It's better to use this method starting from a stock firmware because the script will automatically copy remote.conf and dtb.img from your system to the new rom (experimental)
XTMOD_EX_P .ZIP
Enjoy!
If you like my works and would you like to offer me a beeror a coffe, or a sign of appreciation : SEND ME A DONATION
There are currently 2186 users online. 1 members and 2185 guests.
