Originally posted by ice cube View PostDid you still attached the usb stick to m8s when you type "reboot update"?
Where do I write this line, I have never use this kind of app?
Plugin the USB stick or (preferably) the sd card into the box.
Open the terminal app.
Type reboot update.
Wait.
Originally posted by minixfreak View Postdoes this do 4k youtube? also does it do netflix hd?
http://www.cnx-software.com/2015/12/...os-in-netflix/ <--please read, lots of good information there.
Originally posted by LostEchoes View Post
Turn on the box. Let it launch android.
Type reboot update.
Wait.
That trick doesn't worked for me but I tried the backup&restore app that comes with the box and then I manage to flash the rom successfully! The box respond very well, the only thing I can complain about is the terrible wifi connection. My Kodi and spmc cant play a single movie without buffering every 10-20sec over wifi so I plugged in a Ethernet cable and now I´m satisfied! Maybe there are some settings for the buffering problem in kodi/spmc that I don´t know about? My box stand approx 3m from a tp-link archer c3200 router.
Check here for the "Recommended video settings for Android devices" when using SPMC. You will probably have issues with KODI, on Android devices. SPMC is the right fork for this OS.
Good news XTMOD 2.5 RTM (latest beta online) has to be flashed with Amlogic_USB_burning_tool_2.0.8
It's the fastest rom i ever did, i hope everything goes well, after that i will upload the final next week and .zip files for adding support to wifi 9377 chipset and rockchip bt chips, and then nexbox fix .zip files, obviously all that .zip fixes has to be tested cause i do not own all the devices
Ah i forgot to mention as a experimentation i added a RGB Fix ( Use the Included app, box-fix ) thank to superceleron i hope this come from him if not feel free to correct me
Let me know how it goes...Last edited by Xannytech; 18 March 2017, 16:44.
Originally posted by Xannytech View PostGood news XTMOD 2.5 RTM (latest beta is in upload 1hour from now) it's the fastest rom i ever did, i hope everything goes well, after that i will upload the final next week and .zip files for adding support to wifi 9377 chipset and rockchip bt chips, and then nexbox fix .zip files, obviously all that .zip fixes has to be tested cause i do not own all the devices
There are currently 3940 users online. 1 members and 3939 guests.
