Hello, Xannytech. I try to use your firmware:XTMOD_EX_P and have two problems. My box is T95N Mini M8S Pro.
1. I insert stock remote.conf and my ir-remote now works. But works only if android fully loaded. Key "Power" - work fine for disabling box. But not work, when I want to enable boxFor enabling I need to press key "2". Is it possible to solve this problem and how?
2. When box work ower ethernet - after some time it overheats, and all connections are stopped. When box work ower wifi - all fine. But wifi not so fast, in comparison with ethernet. I dont know, its problem of firmware, or problem of S905x SOC in general.
Originally posted by digitalriver View PostHello, Xannytech. I try to use your firmware:XTMOD_EX_P and have two problems. My box is T95N Mini M8S Pro.
2. i do not think it's a rom problem i did no mod on ethernet side.
Anyone tested new rom version?
I know the old stupid "problems", there is no need to remeber me that some device using my rom done for MINI M8S II has some side effect, i will try to help all, but all has to be done step by step, i wrote in my previous message what i will do in future. So if it's a problem to read... my friends... i cannot help you
Example: user Rasto4nik i wrote to him to read my previous message result: question "when will be posted the final release?"
So please read what i wrote
I know seems hilarious, but also absurd.
Originally posted by Xannytech View Post
It's not a really rom problem, but i will look in minix u9h code if there is something different, on android side it's all fixed, probably it's kodi 17 coding but i can't do nothing i that case.
rly im happy with beta 4
Originally posted by Xannytech View PostAnyone tested new rom version?.
1. First few seconds after start - some problems with bootscreen. I tested on two tv-sets. On previous rom(EX_P) was all good
2.Box not fully powered off. I see the power on usb ports.
If you see, the mouse is lighting. On previous rom was: usb - without power, but in general box not powered off, my tester show me 0.4A current, and 0.01A in sleep mode(I used sleep mode on EX_P rom). Now I dont have idea, how I must disabling box, because now voltage on usb ports there is always on both modes(power off, sleep)
Originally posted by bajann View Post2.You have in mbox settings power off option just select power off and you will see no light on mouse...
_https://youtu.be/uUf_hqisRAA
I will repeat, in previous rom was all fine(for me)
Can you tell me, where is this magic power off option? I use this variant(little video):
There are currently 1425 users online. 1 members and 1424 guests.
