I use your rom for more than 3 months. On 3 Mini M8S II, never had 1 single problem. Never use an XTMOD_EX. Thank you for your great work. I'm not looking for an F-35. Your rom is perfect. thank you Ps: what is (Android TV) or (Android)
j'utilise votre rom depuis plus de 3 mois .sur 3 Mini M8S II , jamais eu 1 seul probleme . jamais utiliser un XTMOD_EX . je vous remercie pour votre super travail . je ne cherche pas un F-35 . votre rom est perfect . merci
ps: c'est quoi (Android TV ) ou (Android )
Originally posted by Xannytech View Post
thanks, no problem to make nexbox power on works, i'll post a experiment .zip later on weekend.
about rgb fix, i just have to experiment myself, but i can't do that, so, that process, it's a little bit longer, and i need you'r help
I'll use my rom, and my knowledge, nothing so different in kernel in my own rom
Yes.....weekend is good for testing.
You are saying there will be another release with power on function this weekend ?
Originally posted by ssarava9 View Post
Using your latest ROM, Nexbox power on doesnt work, copied the remote config file still not working, but all other function works after powering on manually
You are saying there will be another release with power on function this weekend ?just for nexbox, because for obvious reason i cannot test myself. I need at least two "guinea pigs" with nexbox and my latest test Rom installed.
Originally posted by Xannytech View PostTo All:
Anyway just two reports...There is no more interest in my roms?
So no rush for me.
1.I think - your firmware dont have autodetect HDMI resolution. After flashing I have always "out of range" on my old tv(not support 1080p, only support 1080i and lower) in kitchen. And I must went to another tv(fullHD) for manual changing resolution to 720p
2. "Reboot to recovery" from advanced reboot - works for me. And TWRP have autodetect resolution, because I see TWRP(1080i). But after exit from TWRP - system again loading in 1080p, and I again must to go to another tv for charging resolution
3. "Power on" on my remote - not work, work key "2" for enabling box(this history you know).
4. Magic menu - shutdown mode and suspend mode:
Power on usb-ports - always present. After go to sleep: +5V present & mouse go to "sleep" after 15-20 sec. After go to "shutdown": +5v - present & mouse DONT GO to sleep. I must to use only "sleep" mode, because after "shutdown" - mouse always lighting. In both modes from magic menu. Little new video,if you want to see.
P.S. I dont know, might be all this problems are present only in my box(T95N), because something incompatible in hardware. Everything else works at a very high level(not very high temperature(50-70 *C without fun),playing video, playmarket, youtube(1080p 60fps) etc.), thank you!
P.P.S About RGB-fix - I dont know, if this fix works, because on both my tv`s box work correctly.
P.P.P.S In general, I dont see differents with EXT_final_test and previous EXT_RTM (only bootscreen not corrupted)
Originally posted by digitalriver View Post
Hellow Xannytech. So...something about your new TEST version before FINAL Release (or not)....ok.
Balancing speed, smoothness and temperature on these stupid chinese devices it's not so easy
I pratically destroyed mine for testing
Anyway there is a version of my rom that gives you no problem about usb power on shutting down? I would like to know that to identify, what could be... To be clear i tested same thing you did on mine e no problem about usb powered when shutting down, so probably is a T95N problem with my custom.
From video i saw that you used to change launcher and some settings, can you tell me what you did?
Originally posted by Xannytech View PostFrom video i saw that you used to change launcher and some settings, can you tell me what you did?
Hey again,
it works like the ROM before, but faster. The same happend with the 9377 modem but ethernet works.
All in one feeling, smouth and fast ever! ThX AgAiN 4 Your Work! ;-)
Greetings from
Markus
QcoQce TX5PRO 2 GB RAm + 16 GB ROM with Rii mini ONE i28 Gamepad, Display: MEDION LED 32" & HDX 1000 "Multimedia Ext. HDD" 1TB.
Greetings from
Markus
There are currently 6552 users online. 0 members and 6552 guests.
