Originally posted by ssarava9 View PostThe new ROM not allowing to add accounts, not able to access play store, the screen hangs in "Checking info", can someone please help?
anyway you got PM
Originally posted by Xannytech View PostGood news XTMOD 2.5 RTM (latest beta online) has to be flashed with Amlogic_USB_burning_tool_2.0.8
It's the fastest rom i ever did, i hope everything goes well, after that i will upload the final next week and .zip files for adding support to wifi 9377 chipset and rockchip bt chips, and then nexbox fix .zip files, obviously all that .zip fixes has to be tested cause i do not own all the devices
Ah i forgot to mention as a experimentation i added a RGB Fix ( Use the Included app, box-fix ) thank to superceleron i hope this come from him if not feel free to correct me
Let me know how it goes...
First, thank you very much for the job !!!!
The rom works very fast......
The Box_Fix doesnt work correctly, sorry......
I remember that superceleron tells me that his fix only works on his own rom (own kernel).
Other bugs are:
-" Power on" doesnt work on remote
- BT doesnt work
regards
Originally posted by matayuma View Post
TEST Nexbox A95X S905X (2/8) !!!!
Other bugs are:
- BT doesnt work
regards
I'm loving this firmware - it's fast and super responsive. I have a version without bluetooth (1G/8G). In order to enjoy Bluetooth, I wonder if you could assist by choosing a BT dongle (from a common source like GearBest) and installing it's matching driver? Is that possible? It would really help all of the users that wished they had the Bluetooth version.
ok thanks, i modded the kernel to experiment... so no success
Ciao Xanny
If you have time and you want more test
This is supercelerons rom (ROM] Mini M8S II SCV1A-ATV (Android TV)), modified by gatos for Nexbox A95x S905x :
https://mega.nz/#!nZMAhbaA!Y69sYXOGqHzm1...5QzJH9yYFM
- Box_Fix (RGB) works
- Remote works 100% (Power On)
Bug:
- When you reboot in recovery mode , the box hangs (no recovery) and i must flash it again !!!
RegardsLast edited by matayuma; 24 March 2017, 09:16.
Ciao Xanny
Bug:
Regards
about rgb fix, i just have to experiment myself, but i can't do that, so, that process, it's a little bit longer, and i need you'r help
I'll use my rom, and my knowledge, nothing so different in kernel in my own rom
There are currently 1372 users online. 1 members and 1371 guests.
