Dandroid534...Full authority thus 755 or 644? And you have left other WiFi devices in the System/ect/wift folder?
And have only copied the folder AP6330 from the old image (original of August 2016) and copied into the XT-Rom or?
I do not understand waru it nei a Nexbox A5 does not work.
But have already read several problem reports, which there with the AP6330 difficulties and with you it goes without problems?
What do you have for a Nexbox?
Originally posted by fritz122 View PostDandroid534...Full authority thus 755 or 644? And you have left other WiFi devices in the System/ect/wift folder?
Dandroid534 great Thanks for verry importent tip with Root Browser. I have most ever the X-Explorer Filemanger worked (is a Pay Version) and with this
Although root privileges are properly activated in the Root Explorer, the permissions 775 in the WiFi folder for my AP6330 were not accepted. Now I have used your recommendation with root browser. now work my WiFi AP6330 and with 5 Ghz and/or 2,4 GHz.
Again big Thanks for You .. my new Android-Special Friend here.
Changelog from V1:
- Totally rebased rom (MX3 II V110/Mini M8S2 V119 it's a mix);
- Different Memory and Speed tweaks ANTUTU (34600 points stable);
- RGB FIX in settings;
- a New Reboot Menu Framework;
- CPU scheduler Interactive;
- SPMC + SPMC optimizations;
- Updated almost all the system and base apps;
- AutorefreshRate Lvl 1 and Lvl 2 built-in in kernel + level2 could be activated in Settings (framework mod);
- Updated Init.d scripts;
- Added support for AP6330 wifi in system;
- New version just for 9377 wifi devices;
- Trimmed and optimized many ROM parameters for a little bit more speed;
- Fixed some invisible to the user, but ugly bug left by the manufacturer;
- Removed VLC, Added Google Search (i use voice command a lot);
- for sure many things i forgot to write.
DOWNLOAD LINKS:
UPDATED VERSION v2.5 FINAL !!
Flash with Amlogic_USB_burning_tool_2.0.8 or BootcardMaker v2.0.0.2 if you want to use sd method (guide):
XTMOD EX P FINAL (v 2.5) for TvBoxes with wifi chipset : AP62X2, AP4354, AP4356, AP6212, AP6212A, AP6255, AP6335, AP43458, AP6330
XTMOD_EX_P_FINAL_9377 (V2.5) for TvBoxes with wifi chipset: AP9377
NOTE: I WILL NOT REPLY TO STUPID QUESTIONS ABOUT WICH WIFI CHIP MY DEVICE HAS.. AND SIMILAR, GOOGLE IT'S YOUR BEST FRIEND
Enjoy!
If you like my works and would you like to offer me a beer
or a coffe, or a sign of appreciation :
SEND ME A DONATION
NOTE RGBFIX IS UNTESTED SO LET ME KNOW
A big thanks to my friends/testers bajann scooter2014 and to LostEchoes Kuno and to all my supporters/donor!Last edited by Xannytech; 12 April 2017, 19:43.
There are currently 1725 users online. 1 members and 1724 guests.
