    Originally posted by m1tch3m View Post
    Thank you Xannytech!!! Going to be flashing this tomorrow!
    FYI: Your donation link doesn't work, comes up with this:
    Error Detected
    Error Message
    Some required information is missing or incomplete. Please correct your entries and try again.
    FIXED
      @Xannytech how can I change the option for remote control to turn off/reset? I can´t see the option anymore
          @Xannytech thanks. I didn't think your roms could be faster, but this latest version is
            Thanks i simply ported what i use from the beginning in my "personal" more "extreme" rom.
              Originally posted by moreje View Post
              Hello,
              I have the Mini M8s II box, running stock firmware.
              As I have trouble with passthrough DTS on Kodi, I want to test this ROM.
              I have few questions:
              - do I need specific material (USB cable)?
              - the UNZIP to SD Rom will do the job?
              what is the difference between the 2 methods and why choosing one method vs the other?
              - how can I flash back to stock ROM ?
              Thanks for your help
              moreje
              I have the same question..
              I'm flashing custom rom for the first time so i would like to know what method is safer to flash this rom and can i make backup now so i can revert to the factory rom if it bricks? Thanks.
                This error splash on my nexbox s905x gain and again.
                "Unfortunately, Google play services has stopped"
                  Please read what i wrote: Flash with Amlogic_USB_burning_tool_2.0.8 or BootcardMaker v2.0.0.2 if you want to use sd method (guide)
                  You can't brick your device, but you can if you do stupid wrong things, but for me the safest method is the first and with a USB male to male cable.
                  Anyway backing up your rom with TWRP it's always a good idea.
                  I will not reply anymore to such questions, sorry, i don't want to be rude to anyone, but on this forum and on this thread you can find any knowlegde you need, and i and many users replied so many times to the same question.
                  Anyway remember it's your own responsibility what you do
                    With the final? the problem should be fixed two test versions ago, let me know, because i never got that error and it's random sometimes comes sometimes not 2 on 9 testers got it, then i try and fix a none reported that error again.
                    Just to understand better, and eventually discover the culprit which is your system language? Which version you flashed (wifi chip)
                    Eventually try to reinstall the rom again.
                      My language is English and WiFi chip is ap6330 and I have nexbox s905x 1g 8g...I cannot able to add Google account in settings...
                        So, with trial and error test I found that to solve Netflix error 0013 without disabling bootvideo you have to delete/rename libwvdrmengine.so in system/vendor/lib/mediadrm.
                        I don't know if this change can have conflict with another apps
                          hmm interesting thanks let us know if some other app has problem disabling drm
                            Xannytech First of all thanks for the hard work again, i was really looking forward to this final rom, and it really looks awesome! I was really happy to see the button to close all running applications at once. After installing the rom i wanted to download an apk file with the built in Chrome browser, but i am getting the error message: download failed due to missing SD card. In the previous version i didn't have this issue, so what did you change that is causing this?
                            Edit: The fix is easy though, go into android settings - apps - Chrome - permissions. Turn of storage permissions, and turn it back on. Then restart Chrome and enjoy downloading
                              rajawaqas
                              download error
                              re Télécharge la rom tu es 99% et non 100% Re download the ROM you are 99% and not 100%
                                Originally posted by Xannytech View Post
                                Click image for larger version  Name:	XT_SHUTDOWN_MENU.png Views:	1 Size:	129.4 KB ID:	640979
                                Xannytech, thanks again for your work. With your final ROM if you just press the ON/OFF button on the remote, the box goes to suspension, right?
