Originally posted by scooter2014 View PostLast edited by Gravy Boat Captin; 15 February 2017, 20:45.
Originally posted by Xannytech View Post
honestly never tested, but when i came back full time we can do some experiment togheter
Originally posted by scooter2014 View PostWhen i see post like above i have to say Kodi/spmc/Ftmc NOT YOUR ISSUE. Switching to kodi17 from spmc will do NOTHING for your wifi connections what ever is happening is not program related. I have spmc installed on 20 devices Ftmc on everyone of them too. Telling someone that switching to beta 17 kodi build helped your wifi buffering is like stating you put a new heated car seat in your car and you get better mileage now. Nothing related to wifi. Settings and use maybe"HANDS ARE NATURES FORKS" -Rigby
I want to control my box with my laptop's keyboard and touchpad using usb cable...can someone recommend free software for this? Tried mymobiler but it doesn't work, also having problem with deskdock app. When I connect my box (Nex. A95x) to my pc (windows 10) no driver is installing. From where could I get drivers for my box? Also when I open device manager my box isn't there, anywhere...
Only app that works is vysor but free version has very low resolution? Can someone suggest something?
And again in PM new users (0 messages) asking for the 9377 chip version. I answered so many time that now i'm officially bored. Probably is the same user relogged or i don't know but stop asking the same fuc*ing thing
I think manufacturer built a working rom, no obligation for any developer to build a custom for a chip that i do not own and starting in the thread the obviuos: i want this, i want that...
Again for the very last time i hope you'll understand.
Originally posted by Xannytech View PostAnd again in PM new users (0 messages) asking for the 9377 chip version. I answered so many time that now i'm officially bored. Probably is the same user relogged or i don't know but stop asking the same fuc*ing thing
I think manufacturer built a working rom, no obligation for any developer to build a custom for a chip that i do not own and starting in the thread the obvious: i want this, i want that...
I'm not trying to start a rant but I'm just saying it's be nice to not harass these people like Xannytech that are taking time out of their day to develop ROM's and help others. You don't wanna drive them away or you'll just be left with the crappy stock firmware your box gets shipped with lol. BUT if you're patient you'll get a fully working ROM for FREE (well there's donations) if you just be patient ."HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91 View PostAll the people who want stock remote functionality and Xannytechs rom at the same time just follow this. It worked on my x96 but should work on others as long as they're s905x
Before you start you will still need to replace remote.conf in system\etc with the correct one for your remote using a file explorer afterwards unless you pack it in using the tool before flashing, but you have to have the customization on "Set Product Information" to access the level2 folder and change it.
UPDATE: BEFORE DOING ANYTHING YOU ACTUALLY ONLY NEED TO CHANGE bootloader.PARTITION YOU DO NOT NEED TO MODIFY DDR.USB OR UBOOT.USB.
Download this : http://freaktab.com/forum/tv-player-...ion-tool-2-0-7
1. Open the tool (If it's in Chinese the second tab option at the top is Language and the first selection in the drop down is English)
2. Click Load and press the checkbox that reads Replace Uboot/Kernel and click OK
3. Load your stack rom
4. Once it's loaded, navigate to where your currently loaded firmware will be located (The Default should be C:\Program Files (x86)\Amlogic\CustomizationTool\tmp)
5. There should be a folder here called level1. Open the folder, then copy bootloader.PARTITION, DDR.USB and UBOOT.USB and paste them somewhere you'll remember.
6. A. Again Click Load and pressing the checkbox that reads Replace Uboot/Kernel
B. OPTIONAL If you want to pack your remote.conf in now, also click Set Product Information(Unpack System Partition) and then click OK
7. This time select the Xannytech rom
8. A. Go to the Advance tab and click Uboot and replace the 3 files with the ones you copied earlier OR go back to the level1 folder from step 5 and replace the 3 files either way is the same.
B. OPTIONAL: Replace remote.conf in the folder C:\Program Files (x86)\Amlogic\CustomizationTool\tmp\level2\system\ etc
9. Press Pack and save it wherever you want (you have to pick a new name you can't overwrite a rom with the same name or the program gives an error)
10. Flash the rom using USB_Burning_Tool and that should make the power button on the remote work to turn on the box.
Note: Doing this made my recovery not work properly but I couldn't change the Kernel or I'd get stuck on the splash screen. Hopefully this helps a few people that want stock remote functionality and a decent rom and just don't know where to start.
Originally posted by steocullen91 View PostDid you try with all 3 files just in case your box is different? Also remove the sd card if you have one inserted with recovery on it.
Do you want me to try with only UBoot file and leave the other two intact ? i will try again today evening and report out
The process is very simple, thanks for putting up for us to learn.
Originally posted by ssarava9 View Post
Yes i tried with all the 3 files, SD card was not inserted.
Doing only bootloader alone made my remote power on the box again. If your ROM is very different to Xannytechs then all 3 files may be making it fail to boot so it's just loading into recovery instead."HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91 View PostTry only changing bootloader.PARTITION and leave the other 2 and see if that works for you. Different boxes get different results again on this due to different hardware unfortunately.
Originally posted by fluoir View PostI want to control my box with my laptop's keyboard and touchpad using usb cable...can someone recommend free software for this? Tried mymobiler but it doesn't work, also having problem with deskdock app. When I connect my box (Nex. A95x) to my pc (windows 10) no driver is installing. From where could I get drivers for my box? Also when I open device manager my box isn't there, anywhere...
the software in the play store is the same. A lot of those devs do it as their full time job. So without your support there will be no more software like what you want. Buy it. Support the devs.
Thanks i will try today evening and report back the results, thanks again for helping out
Anyone knows how to add resume and reboot option when pressing power button, right now its directly shutting down the device
The option just replacing bootloader.partition works, thanks a lot for your suggestion.
Best thing to do is use the beta 4 of xannytechs firmware from this post. That has the power off menu when you press it. Only thing is you'll have to replace the bootloater.PARTITION again."HANDS ARE NATURES FORKS" -Rigby
Originally posted by jmgandia View PostI'm trying to mount my nfs server from command line but busybox mount does not work. Do I need to update busybox? How? Anyone has mounted an nfs server form android?
I've same question, I try this h**ps://forums.geforce.com/default/topic/856208/-guide-how-to-mount-a-network-share-into-the-filesystem-root-/ but cifs manger fail and SELinux seems disabled.
Somebody can help me? thanks
Somebody can help me? thanksit's not a ROM problem so please...
I would not seems too strict, but this thread will become a mess...
There are currently 2886 users online. 1 members and 2885 guests.
