    Originally posted by jakotaki007 View Post
    I missed that. Firstly i've flashed my original fw from TWRP and then libreelec also from TWRP. Like i said with first issue a can live but this remote... Xannytech do You know where is map to power on button? Also in remote.conf?
    Regards
    it's odd cause that type of behaviour is typical of a device with a bootloader not meant for your device, from the bootlogo distorted going to the power on not functional. There is nothing wrong in your remote.conf.
      Hi, installed on TX5 (not pro) 2gb/8gb and works excellent, the only issue is netflix not works, error 0013 its possible to solve.
      Sorry for my english im spanish
      Regards
        So i must install good bootloader?
          Regards
          edit /system/build.prop service.bootvideo=0 and it works, i think it's a netfilx bug i hope tey will solve in next release
            you need to flash your original firmware not through twrp, then reinstall twrp, and reinstall libreelec, i don't know why but seems that when you flashed back original fw (not custom) your bootloader wasn't flashed correctly.
              Originally posted by hjpca View Post
              this will not work ..I think we need kernel or wifi .ko in lib...?
              Try this copy in /system/lib the .ko files and give them 644 permissions
              Not sure it works, but i tried adding a backport library, it's an experiment. Let me know.
                Originally posted by dssnobie View Post
                I was traveling few days and didn't participate.
                Xannytech,
                If you would like to try, I can test f/w for 6255 wi-fi chip on the tx5pro. Here is the link to latest stock f/w. http://www.mediafire.com/file/1d8acc...5-20161123.img
                Thanks mate, but 6255 drivers are yet inside my fw:
                Code:
                [B]Wi-fi firmware actually in etc. ( i will add later the reported working during these days of tests like 6330)[/B]
                - 62x2
                - 4354
                - 4356
                - 6212
                - 6255
                - 6335
                - 43458
                  well... i think i'm retarded. I do like You said. But it flashed and reset. MBOX was showed up and i think its looped so i turn it off and i can't power on anymore. Nothing happens when i pug in power cable. Only red diode is shining ;(;( I've tried everything and nothing. Some suggestion or i'm bricked my first device in my life?
                  Regards
                    Regards
                    i don't think you bricked your device
                    At a first look probably your device was just loading stuffs for the first boot and you interrupted the process brutally.
                    But now sd card method does not work anymore?
                    If this is the case a fast fix is to flash back the original fw through Amlogic_USB_burning_tool
                    Anyway your device is a
                    Mini M8S II clone if i remember well?
                      Thanks, works fine.
                      AWESOME JOB Xannytech
                      Regards and thanks again
                        I have T95X. I really don't know of it's M8S Clone but Your rom work well. But Amlogic USB burning tool work when device is on standby?
                        Edit
                        Ok. i read the device must be off so maybe i'll bring it to life
                        Edit
                        I was wrong - i must power on device but i can't. reset button and plug in power cable didn't work. Any ideas??
                        Regards
                          Edit
                          Edit
                          Regards
                          :O wow ... hmmm or with that tool or sdcard method, but your device is not recognized by windows or what?
                          Have you tried to load Firmware.img on usb tool and press start without connecting the device and then plug the usb in? probably should start to burn.
                            I messed up My cable was not properly inserted. I made i from extension USB Everything works flaweless!!
                            Sorry for littering this topic.
                            Thank You Xannytech, I owe You!
                            Anyhow i can confirm that Your rom work in Sunvell T95x 2gb/8gb
                            Regards
                              Regards
                              do not worry i'm happy you solved... and yes your device is a mini m8s II clone
                                Hi, i have a strange problem. Uninstalled kodi 17, and installed 16.1 and after it started the device is shutting down. WTF?!
