Originally posted by jayort View Post
Nexbox A95X S905X 1Gb/8Gb November folder
But for all the other users is the first and the last time. just to not become "chinese box" call center boy
Here is your firmware flashable with TWRP :https://mega.nz/#!1x1HzRbB!rJ7pED4kJ...13clhYtGjn4JeU
Unzip the file i provided to you in an empty SD card then reboot to TWRP click install choose the .zip file and all should be done.Last edited by Xannytech; 02 January 2017, 23:52.
Hi Xanny,
i just purchase a Beelink MKIII-II(still waiting for it to arrive) searching through the internet and found your rom compatible but lack of wifi support. is it possible for you to make a fully workable custom room for the device?
the device detail as link below:
http://freaktab.com/forum/tv-player-...-10-100-lan-bt
Thank you in advance.
Best Regards,
FG
Originally posted by Xannytech View Post
ok i'll give you a link in two hours.
Best Regards,
FG
i'm joking i cannot accept such request or my life will become an inferno...Last edited by Xannytech; 03 January 2017, 11:01.
Originally posted by jayort View PostHi Xanny. Thank you again for the Nexbox A95x imprrovised firmware you've made. I also heard from another Nexbox A95x owner but with 2gb/16gb that the reset button ( using toothpick) failed to function after flashing your firmware. Just for your info.
But using TWRP as recovery you have to flash the correct files, your manufacturer use a non standard way to work with recovery, so as i explained before you need a script that is the standard way to work with recovery, from the beginning of Android era.
Give to him the fw i linked to you and then he can upgrade again the right fw for him with nexbox non-standard sd method
The reset button works as it should, and again no software can block an hardware switch that simply shortcircuit two pin.
But using TWRP as recovery you have to flash the correct files, your manufacturer use a non standard way to work with recovery, so as i explained before you need a script that is the standard way to work with recovery from the beginning of Android era.
I reposted your link in the official nexbox forum and i mentioned that you made the appropriate workaround on the said official rom. I did mentioned also that its only good for nexbox a95x s905x with 1gb ram and 8gb storage. He has 2gb/16gb...so will he just change the official rom file from 1gb to 2gb file from you package and the rest unchanged? Thanks.
I suppose should work.
DO NOT MODIFY MY ZIP, YOU DO NOT HAVE THE KNOWLEDGE AND SKILLS TO DO THAT. WILL NOT WORK.
NO jayort he can flash using the zip i done for you, and THEN flash back his appropriate stock FW, cause using the zip i provided to you the original recovery is FLASHED back.
Xanny, of course I will not modify nor suggest anything that i dont have knowledge of that' s why I am consulting it from an expert like you. Dont wanna be the caused of a brick tv box. I rest assure you of that.
But... i was replying and warn you for that :
yes is possible, but not just for a single user or you should pay for a personal custom
no problem. then i will most probably stick to the stock rom untill further development.(dont think will)
anyway, thanks for the reply.
Regards,
FG
There are currently 3020 users online. 0 members and 3020 guests.
