Originally posted by makavelio View PostCan I install this with TWRP? Also has anyone got the remote.conf for Mini M8S II please? I will be coming from LibreELEC which my remote stopped working. Thanks
Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by cjeman View Post
I found it on this post in remote.zip. It works with this ROM
http://freaktab.com/forum/tv-player-...7-0-for-s905-x
Originally posted by hjpca View Post
I can test for you..if you need me
Copy the named "firmware" folder in /system/etc/wifi/ give to the folder permission 755, and give to the files inside permission 644.
Then copy the files form folder "lib" in /system/lib/ give to them permission 644
then reboot.
Open the teminal app and write:
Code:insmod /system/lib/compat.ko insmod /system/lib/cfg80211.ko
And write back to me results (and obviously check if wifi is working).
That test will not harm or block your device, so it's easy in the worst case simply does nothing.
Thanks a lot for testing
P.S.
I'm simply trying to force load the modules, and see if we can just fix simply doing this...
Originally posted by Xannytech View Post
Download these files it's a single .7z compress file but inside are your wifi firmwares files and some modules to be installed in system /lib.
then reboot.
P.S.
hi I been trying lots of times to get this to work..no go yet.../system/lib/compat.ko: no such file or directory..that what I am getting
if you do a ls /system/lib/*.ko can you see the compat.ko file?
Originally posted by hjpca View PostI can see it when I go into system lib compat.ko file
so from what i can understand... The file are not in the /system/lib/ directory.
Just for be sure:
go in terminal
type:
su[enter <---means push the key]
chmod 644 /system/lib/compat.ko
if this gives you a ":no such file or directory" ... you'll undestand that means there is no file
i did the test myself but i cannot check if a wifi chip not on my system works, so i'm quite sure that insmod will load the modules in memory.
Just for be sure:
go in terminal
type:
ok I did this..i get chmod: chmod'/system/lib/compat.ko' to 100644: read-only file system
i'm quite sure you're giving command not from a root shell (or not as superuser)
to avoid any problem it's better to use adb shell, but i do not remeber if you have a connection of any type with your device, and from what i understand you obviously (without any offence) you're not so skilled
There are currently 2929 users online. 0 members and 2929 guests.
