Originally posted by KodiLoaded View PostFirmware runs great with one exception, I have tried it son several nexbox models and the remote.conf works for everything except you cannot turn the box on with the remote ! Big problem.
EDIT
Bluetooth is also porked
Unfortunately I have the same problem - can't Power On from the remote. I also noticed that Power Button icon disappeared from the Settings window. Power button is shutting down box, but nothing happened if I try to turn it back on, had to unplug/plug power cable. I used "image load via USB port" for XannyTech ROM installation, box is TX5 Pro
I reverted back to stock ROM and power button working as expected and settings are back
Please help to restore functionally, I'd definitely prefer this ROM instead of stock.
Originally posted by dssnobie View Post
First of all I'd like to thank you for the excellent job. ROM fixed a lot of issues, clean and fast.
Please help to restore functionally, I'd definitely prefer this ROM instead of stock.thanks, i know that for users is difficult to understand that some of the "issue", like wifi, or power on are not bugs, the rom itself is based on a different device (Mini M8S II), so sometimes works everything perfectly on different devices, sometimes not.
The only thing i can do is investigate, and if i cannot find a easy solution, port my rom on that device, that means mod a new fw for a different device, but it's a matter of number of users (i will not use my free time for 10 users) and my personal freetime.
Any fw i prepare need many days of work and testing, so you can understand what means.
XannyLast edited by Xannytech; 31 December 2016, 02:31.
Originally posted by Xannytech View PostKodi 17 RC is out: "we can now tell you that passthrough for DTS, DTS-HD, DTS-X, Dolby TrueHD and Dolby ATMOS should all be working if your device supports this."
If someone would like to test it
that's strange cause i use Netflix... and i haven't got any problem...i have to reproduce the problem myself to solve it. But anyway if just modding build.prop make it work no problem.
If you need more brightness edit in /system/etc/int.d 05videobrightness like this:
Code:#!/system/bin/sh echo 10 | tee /sys/class/video/vpp_brightness
Hello,
sorry, but I have difficulties to understand the purpose of XTMOD_EX_P .IMG (it's in .7z format just for space reason)
Is is an updated version of the link given upper :
MINIM8SII_XTMOD_P .IMG file or MINIM8SII XTMOD P +TWRP RECOVERY .IMG file ?
if yes, with or wothout the TWRP ?
Regards
Originally posted by mallox View Post
I try DTS with Kodi 17 RC on my Nexbox A5 (XT ROM - version 2) and the passthrough activated... No sound
It haven't worked right after it was enabled on the existing Kodi installation on TX5 Pro. I uninstalled/re-installed Kodi to eliminate possibility of the existing setup messing with passtrhough. At first passthrough didn't work anyway, but after 10-15 min I turned off AV receiver and then turned back on and suddenly passthrough started working. Not sure if receiver power cycle was a coincidence.
Originally posted by fbp View PostI have difficulties to understand the purpose of [B]XTMOD_EX_P .IMG (it's in .7z format just for space reason)
Is it an updated version of the link given upper
The only thing i can do is investigate, and if i cannot find a easy solution, port my rom on that device, that means mod a new fw for a different device, but it's a matter of number of users (i will not use my free time for 10 users) and my personal free time.
Xanny
Please let me know if I can help investigate or test. I have some knowledge of electronic devices and rudimentary understanding of Linux use.
Hi. I have Nexbox A95x S905X 1GB/8GB and I just installed your latest firmware via SD card from Stock Rom. Installation was successful but remote control never worked since I forgot to take note of the remote sys. I would like to revert to my stock rom but unfortunately, the AV reset button does not work anymore when I hold and put power on.....since it just opens the normal way... I need you assistance. Thanks
Originally posted by jayort View PostHi. I have Nexbox A95x S905X 1GB/8GB and I just installed your latest firmware via SD card from Stock Rom. Installation was successful but remote control never worked since I forgot to take note of the remote sys. I would like to revert to my stock rom but unfortunately, the AV reset button does not work anymore when I hold and put power on.....since it just opens the normal way... I need you assistance. Thanks
i know it's a pain to read the first message but could be useful
if you want to go back to stock rom, simply reboot in twrp and install your fw (in sd format) back.
To reboot in twrp recovery use the reboot program built-in in rom...
second way to restore your fw back amlogic usb burning tool a firmware in .imf format and a male to male usb cable, you can do it yourself simply cuttng two spare usb and connect the 4 cables are color coded.
There are currently 2929 users online. 1 members and 2928 guests.
