About judder and stuttering: is working the hdmi self-adaptation setting? I don't see any difference with or without enabling it.
Originally posted by jmgandia View Post
I will try to flash your rom this afternoon if I can. About kodi, is it normal kodi not noticing change in display frequency? If I start kodi before I remember to change to 24p, then I have to exit kodi and run it again.
Now back in topic:
Flash it through TWRP and let me know... it's important for you and other nexbox users
NEXBOX BOOTLOADER
Probably it's due to tv, hdmi cable, or dunno i never had problems, but just remember that are just 30$ devices, Nvidia Shield is the solution for all but it cost 10 times than cheap chinese box
Im own a docoler R39X, which is stuck after 2 days
... the box shows only MBOX cubes on screen in couple minuts, then start to uppdate apps on it "Uppdate app 1/41" after all apps uppdates it shows MBOX cubes on screen around cople minuts again, then start to uppdate apps again, and that can continue in days and weeks, it cant start and show startmenu....
I tried to resset and unmount lock under and se motherboard in this box and i coudnnt find reset button mounted on monstercard behind "AV" slott ... so i cant du like other who shows recovery and firmware uppdate for similar boxes...
i tried and tried - no success
Dont buy this shitboxBuy Docooler R39X Smart Android TV Box Android 6.0 S905X Quad-Core 1G / 8G KODI XBMC UHD 4K 3D Mini PC WiFi VP9 H.265 DLNA Airplay Miracast HD Media Player US Plug with fast shipping and top-rated customer service. Once you know, you Newegg!
What I say about kodi is that it's annoying that if the display is at 24hz and I want to play a video at 50hz, then I have to change display settings to 50hz, then exit kodi and start kodi again or kodi will not detect the change and we'll have judder (kodi settings/system info/hardware still 24hz). I am not talking about auto frame rate change, but about kodi checking if the display is changing hz so not introducing puldown judder.
Originally posted by hariconius View PostIm own a docoler R39X, which is stuck after 2 days
http://www.newegg.com/Product/Produc...9SIA1GK5526392
Anyway i understand your frustration but you're a little bit OFF-TOPIC
gimme a link to your fw i will see what i can do
Heres the firmware link for tx5pro 9377wifi from geekbuying
when is ready i will post a test release open to whom had wifi issues so wait just some days.
But for now:
https://mega.nz/#!plVhCD7S!FNOupsbsP...DWMc3JJ5mvQ_YI
copy AP6330 folder in /system/etc/wifi . Obviously give to it the right permissions AP6330 folder permissions 755 and give 644 to all the file inside the folder. Reboot and let me know.
Any chance in next version that we get the DTS working? because on Nexbox the passthroughfix.apk doesn't fix any passthrough (at least HDMI) and scew (robotic sound) after using the box for a while.
Thanks again for the good work
Originally posted by mallox View Post
Yes Wifi is working. Did you modified the files or it's just the permissions changes that allow it to work?
copy firmware folder in /system/etc/wifi . Give to it the right permissions: firmware folder permissions 755 and give 644 to all the file inside the folder. Reboot and let me know.
Not sure will work there are also two kernel modules in lib... but test it.
NEXBOX BOOTLOADER
And what does it change other than being able to flash back to stock with a SD card?
I flash my ROM with USB burning tool, should I also do it?
Originally posted by Xannytech View PostFlash it through TWRP and let me know... it's important for you and other nexbox users
NEXBOX BOOTLOADER
There are currently 1462 users online. 2 members and 1460 guests.
