Originally posted by Xannytech View Post
No, and if it run instead of Bootvideo probably you'll got your video darker due to the very well known darkvideo bug.
Originally posted by manvel View Post
I tried with "original" XTMODE3 also (without sk) , so may be you right it works only with TV beta 3 version..Last edited by fluoir; 26 October 2017, 15:35.
I am getting this error when I try to repack rom with aml tool: "fail to pack images to complete image"
A few hours ago I was replacing same files and did not get the error.
I have been getting it from time to time and eventually I was always able to repack so I was
ignoring it but now i got it maybe 10 times in a row. It drives me ******* crazy
I searched the internet and I have found only 3 people ever posting about this - one of them was me. What the ****? Is it problem with my pc or what ? I don't understand.
Originally posted by fluoir View PostI am getting this error when I try to repack rom with aml tool: "fail to pack images to complete image"
1. Java not setted correctly in your system;
2. don't keep open Usb Burning tool during compilation/decompilation,
3. you forgot some files if you delete or rename wrongly some files this error could occur.
Then i use a different way to compile/decompile, so please decompile just level 1, or you'll get more than a single problem.
Anyway changing bootloader unfortunately does not work for all the nexbox, so many motherboard with the same brand and specific.
Originally posted by pierrottls31 View Post
That will be good if we can have a proper 7.1 XT mod for those boxes
Then your guessing it's right many partition location are changed, but do not mess with reset and so on or you'll get stuck with 7.1.2.
I know how to reflash back 6.01, but it's not easy for everyone.
For the last reason, dunno if a XTMOD based on 7.1.2 it's a good idea, i can prepare it easily, i'll port directly my personal 7.1.2 rom working on a S912 device perfectly, but could cause many problem regarding remote (cause it's coded in a different way), could cause problem with bootloaders, you're lucky, with your device, me not...
So i probably prepare one of this, in spare freetime, but not sure about publicly posting.
TWRP for 6.01 cannot work properly on 7.1.2 64Bit.
Sorry, I did not mean to be rude or anything else... Im not a dev so I probably misunderstood
Anyway, I understand what you are saying about going to 7.1/... I have a 1/8Gb version of A95X so I'm just looking at the fastest rom...
I'm use to create some ROM for A13 device and use to use /dev/nanda, nandb etc for parition, if you have a minute, can you tell me where to find those partition on Amlogic?
BTW, I just rapidly test your beta ATV rom... and it is really fast... one of the fast rom I have used on my A95X...; Wifi and LAn tested OK.. Did not do extensive test yet with recovery and/or root.... Will test later, but keep up the good works, this ATV rom looks really promising event so it is in betaMaybe you should create another thread for this ROM, i'm sure many of us will be interested
Cheers
Hello,
Cheersnothing in your mesage seems rude to me, i just explained few things not just for you but also for the others that are reading here publicly to avoid problems or request.
For the users that got Google Play Bug i prepared a zip to be flashed trough twrp.
I tested myself but let me know if all it's ok
XTMOD3_MARKETFIX
Thank you Xannytech for this very good Rome of you.
I have a TX 5 Pro Box on this runs the Rome very well,
but have only a small problem, I try to install all the time Magisk.
Have the original zip of xda-developers.com, unfortunately, the installation via TWRP always breaks with the message Error 1.
Have also tried with the unSU Script zip Supersu to uninstall what
Root Checker is also displayed which is supersu uninstalled.
In many forums is said to install the original BOOT.img, this is unfortunately by
Xannytech not offered.
Has anyone of you managed to install Magisk.
please excuse my bad Englisch Many thanks for your help
Originally posted by Colossus View PostThank you Xannytech for this very good Rome of you.
Just for your information, also with Magisk installed you'll never get "Safetynet Passed", because selinux is disabled, and many other reasons, so it's really stupid lose time on it.
Anyway if you seaach a little bit there is also Suhide from Chainfire that has the same feature as Magisk.
There is also a Xposed Module SudoHide.Last edited by Xannytech; 28 October 2017, 14:11.
There are currently 1662 users online. 0 members and 1662 guests.
