Originally posted by rasplinjac View Post
Originally posted by Xannytech View Post
Hmm, i think on original firmware there was kernel support and software support for that LCD, so it's not a simple task to get it back funcional, pratically i should port my rom on your original firmware. And i think i will not do this work for just 1 device...The display is irrelevant anyway. thank you man
I have a different question and may not be relevant to this topic but still want to ask since the experts are here.
I have backed up Nexbox A95x which has Xanny FW using TWRP recovery from SD card and restored in the same box multiple times after trying different other custom firmware, but last night when i was trying to restore to a new nexbox A95x (same configuration like my first one) it restores the backup successful but when rebooting it goes to stock recovery always.
I tried the restore process multiple times and every time is a success but box continues to boot to stock recovery and i even tried to reboot to system from stock recovery but no success.
Anyone faced this and have solution on how to restore the backup using TWRP SD card to a different box which has same configuration ?
Hello
I wanted to add an exception to the local.prop file and lock YouTube for Android TV (Android TV) 2.02.08 but when i add and reboot TV-box. Unfortunately it does not work, for applications you have added yourself like KODI or SmartYT, it works but why not for YT??What am I doing wrong?
My box - NEXBOX A95X 2/16
Originally posted by DhiJay23 View Postany AndroidTV version update?
The 1.0 to be, i got no freetime to post it in a new thread...
Anyone can help me with this?
It is not only a problem with this rom but EVERY custom rom I tried so far.
I enter a VPN in Android settings / network / vpn. I press the + sign and it will ask me to create a personal pin.
I create my pin and enter the details of my VPN, and connect. Works fine, and each time I go to network / vpn it shows the vpn I entered.
After I reboot the device the screen in Android settings / network / vpn is empty/blank.
I need to press the + sign and enter the PIN before I can see the VPN I added before.
With stock ROM it will show the previously added VPN without the need to press + sign and enter pin.
There are currently 2650 users online. 0 members and 2650 guests.
