Originally posted by Xannytech View Post
Originally posted by steocullen91 View Post
Same happened me. I had to set up the USB tool and hit start first, then plug in the cable to my pc and it started. The box doesn't need the power cable plugged in it powers through USB for the process.
I have 2 options: Try to resolve bluetooth problem or find a ROM I can flash from Recovery, which han't found (In Xannytech ROM I can reboot to Recovery from Quick boot app).
Originally posted by FunboxA95X View Post
I do that without success. I follow every video how flash A95x withou sucess (Amlogic USB Tool, Male-Male Cable and with ou without toothpick)
Just for my curiosity which version of my rom you tested? Beta or stable? Because in beta i added some BT fw.
Use this file i posted earlier in this thread, it's done for a nexbox 1/8 but after flashing through twrp you can flash back the original nexbox fw you choose.
First I flash with stable on post 1# then upgrade with Beta ROM SD file from post #611
Originally posted by FunboxA95X View PostI did that...
My original ROM I flash with Xannytech ROM from SD Card ROM file. Loose Recovery from switch. Bluetooth did not work, so I flash again with Beta ROM from #611 with SD Card ROM file from Recovery.
Bluetooth is the only problem I have with this.
Xannytech I have to say I love the rom it's so fast and really stable."HANDS ARE NATURES FORKS" -Rigby
Originally posted by MasterBoy71 View PostHey Xannytech,
is there someone how can check the problem with the 9377 WLan?? I do not say, that it is so much possible, but 4 me sure!
If someone find some time to check! Whould be nice!
Greetings
Markusso they compiled a rom just for that chip. I should do the same thing, i will do it, but not soon cause i'm very busy IRL, but assure that when i'll post the final rom i will also post a 9377 version and a nexbox version of my rom.
I read in another forum that Nexbox A95X have differents BT chipset:
OS - 5.1 / CPU - S905 2.0GHz / RAM - 1GB / ROM - 8GB / WiFi - 8189ETV
OS - 6.0 / CPU - S905X 1.5GHz / RAM - 1GB / ROM - 8GB / WiFi - 8189ETV
OS - 6.0 / CPU - S905X 1.5GHz / RAM - 2GB / ROM - 8GB / WiFi+BT - RTL8723BS
OS - 6.0 / CPU - S905X 1.5GHz / RAM - 2GB / ROM - 16GB / WiFi+BT - AP6330
My is RTL8723BS (Wifi+BT), is drivers missing?
Originally posted by FunboxA95X View PostI read in another forum that Nexbox A95X have differents BT chipset:
Point of the situation...
I flash my Nexbox A95X 2g/8g with Xannytech file on post #844 (used Quick Boot apk to boot recovery,
and install from EXT SD card - Strange the recovery was original android recovery, not the TWRP)
Now boot normal to Original ROM from 1G/8G without Bluetooth option on System Preference, and Switch Recovery is working.
I connect Nexbox to PC via USB cable and now USB Tool dectect nextbox, something It did not do before
(connect USB cable and then connect power cable)
So I'm on original 1G/8G ROM and will flash to a new ROM, if Xannytech have a solution to him bluetooth ROM I will flash it.
There are currently 3318 users online. 2 members and 3316 guests.
