Originally posted by rajawaqas View Posti m just begginer user kindly upload the a95x based xanny rom in which power on option working
Originally posted by joao.feijo View Post
Yes there is. I tested one with this function but i dont remember wich one was."HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91 View Post
I took the Xannytech rom you modified the uboot in and just put my 3 uboot files in instead and that rom has the suspend function or hold power for a power menu exactly as I wanted. For some reason the original Xannytech one didn't do it and yours does if there's something else you modified. It's doing exactly what I want now for some reason
Do not mess too much with uboot and bootloader, please... and if just changing uboot and bootloader works, it's easier for me, but anyway this will not solve some driver problem, there are three version of nexbox with different hardware if i do not recall wrong, and manufacturer indeed provide three different firmwares.
Originally posted by Xannytech View Post
he used my beta probably
The rom seems to work really well. I'm actually waiting on an airmouse remote to get here but I still want to have the remote working
Recovery button also still doesn't boot but that's not too important I can use reboot recovery if I need it that much."HANDS ARE NATURES FORKS" -Rigby
Thanks Xannytech !!
I ordered a mini m8sii last week out of curiosity ! I'm a Rpi user and this is going to be my first experience with Android TV, I see i am going to have to do alot more researching
First off thanks, I've spent the last few days reading up on this box bugs, hdmi range, green screen, HDD rw problems, remote problems. So I've already made up when the box comes your Rom is going to get flashed !!
I have one question, I know this rom is based on the mini m8sii but would you recommend me to install TWRP first on the "factory sent" stock rom and make a full "nandroid" backup (as you called it) just so at least I will always have to original drivers and all the lib files etc?
Or is this really not necessary ?
Thanks again I'll sort you out a beer once I'm up and running as it seems forums like this really are worth their weight in gold when it comes to these cheap boxes
Sent from my HTC One M9 using Tapatalk
Xannytech,
i returned to this thread after a month.
Is there a way that someone can say if you have uploaded a newer version of your rom?
I cannot find a way except to download the file and see the timestamps in the zip and compre them with the ones i have from my previous download.
Is there any easier way? (e.g. maybe you should write in first post an increasing numbered version of your mod)
Regards.
Regards.
just few weeks and i will stay more focused on forums.
Originally posted by rajawaqas View PostXanny I m testing modified version of your Rom for nexbox (where device wake up works )...no errors and bugs ..all options are working smoothly thanks to joao.Feijo for great modification to wake up nexbox..i never tested it, but anyway worth the time spent if i can help you.
There are currently 2652 users online. 0 members and 2652 guests.
