Originally posted by mallox View Post
No didn't solve it. I did enable dts passthrough in kodi. But problem not just with kodi, same with plex. Plex report that device do not support dts passthrough. Will try with other media player if it's the same.
And by the way I don't have any problem so far with DD passthrough.
Originally posted by wolfynwo View PostYes, evrytime you reboot, you have to do it.
Hello and congratulations on your custom rom hack!
to write to you I am helping with google translator! (I apologize).
I downloaded the zip package version, Flash run correctly only on the second attempt, the first attempt the box went botloop ...
However a great job well done!
My tv box is GM T95X 2 / 8GB
Look for more 'extensive tests on the weekend!
Originally posted by Roby34 View PostHello and congratulations on your custom rom hack!
Originally posted by Xannytech View Post
I would like, but, i don't use it so i can't test and give you a solution, i was hoping some other users can suggest you the right setting.
Xannytech
Just to let you know (I don't know if it can help you with your futur poject) but Nexbox unveiled its source code for Amlogic S912 and S905X SDK in the last weeks in there forum.
You can found in
Friz's Nexbox File Repository:
or direct link from Nexbox admin
You can found in
https://mega.nz/#F!1YJHFKZT!Zfm7I_QgnftGlnQYYCGLPg
Some news on my work on this Custom Rom
Actually i have ready a new revised version of the Rom, but i'm waiting if someone can give me v107 firmware (if really exist).
What i did until today:
- Init.d Support Built in (without any external program);
- Removed Init.d Zipalign script pratically unuseful on 6.01;
- Added Sd speed optimization tweak:
- Fixed a unharmful and almost invisible linking bug caused by Amlogic Customization Tool that i used for fast customization process.
- Added in Kernel AutoRefresh Chmod Permissions;
- System Memory optimizations;
- Updated some apk;
- Removed some unuseful APK
To do before release (i hope):
- Add Reboot Option on power menu - but it gave me many headaches.
- Chromecast Service
- Reworking on more elegant solution for some fixes.
After that release if all will be OK, i will just work on a Android TV Version, probably unaploadable on forums cause i should use so many dirty hacking to apks, but i hope i can find a more "elegant" way.
There are currently 2496 users online. 0 members and 2496 guests.
