[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
superceleron or whomever can help. I recently received my Alfawise H96 Pro+ 3g/32g US plug (DDR 3) android box and the wifi reception is lousy! I have an older Q-box in the same area and it gets 13-16 Mbps, while the Alfawise only gets .5-2 Mpbs. I am not very happy with this box and Gear Best is doing little to help me out. I am tempted to flash the box using the method above, but fear that the wifi issue will not be resolved. Is there a way to resolve the "lack of" wifi reception to this box? I have tested this out on several different locations (mom's and friend's house) and I got the same result of the lousy connection. I did note however, that if the Alfawise is directly on top/or below the router I get my close to what my other box gets. I know I will not get full contract with ISP speeds via wifi, but know it should be more than .5-2 Mbps! Any help would be greatly appreciated! I have been looking for more info on this and have not found much!
Can anyone help please, I enabled the restricted profile in the menu and left the default setting for apps ie allow settings menu only. When the box boots now I only have access to the settings menu (as expected) butthe only options are network, about device, accessibility, add accessory and remote. I cannot find a way to enter my pin and load my full profile!
Anyone have any ideas how to log back into the main profile?
Thanks.
Nop, mine have the same problem... its a hw problem even with the stock rom dont work!
I will detail it when I can find it again.
All I can remember is You have to change it from SLEEP MODE to POWER DOWN mode - Then the REMOTE can make device SHUT DOWN (Power Down).
I've Been trying the various ROMs - Thanks SuperCeleron and MegaTrendz!
I tried flashing this ROM thru USB burning tools on my H96 Pro+ and I am getting ERROR= 0x10105002 Romcode/Initialize DDR/Read initialize status/USB Control setup error ... It originally took the SCV3-ATV using SD Card method...but this one wouldn't work that way, for me.
Anyone know what this ERROR code means?Last edited by Wyle; 26 May 2017, 16:16.
There are currently 1872 users online. 3 members and 1869 guests.
