[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
    the r-box-pro uses the same mother board some rboxs have a different wifi chip
      tomorrow i should rls SCV3-ATV in a new thread!
      Very good news thank you so much continue your good work my box now is more fast and all work perfect
        Yes i know, one of my testers have one but is the AP chip!
          I took the plunge and installed. The installation went smooth. I'm in the process of testing. I used the SD card method.
            thanks for the great work on this .
              well it will use the stock kernel, i cant use mine on it since they use a custom kernel with their won mods and my kernel dont have it so no led control sometimes on sleep if it sleeps at all and no poweroff i mean sometimes it powers off but must of the times dont... but you guys will loose my proper rgb fix :/
              But i will give you guys a zip to flash my kernel by twrp to the ones that really need a proper rgb fix.
                Hi all.I have the H96 Pro+.Because i prefer the method installation with microSD card,ican"t found the port for reset at this device.
                  I take it your looking for the reset button . its the tiny hole on the side with the USB ports .
                    Thank you very much!I found it finally!
                      Hi all.Thank you for this new rom.One question.How can i connect this device with my pc wthout cables.In another tvbox (xiaomi mi box 16-aa) is very easy with ip address.
                        So you mean if I install ATV version my box won't power off or go in sleep mode ?
                          nop... i mean if you need the proper RGB Fix (some old sony/philips tv's) you have to use my kernel (stock one the fix if not ok it comes back the green/pink screen after a while) and my kernel have those problems.... if you dont need it everything is ok since it uses the stock rom.
                          And keep ATV rom questions in it thread/topic plz.
                            Originally posted by jlgmax View Post
                            Hi, I updated my H96 pro box using the Micro SD method - all is working OK except I could not see the Kodi app. I reinstalled 16.1 from the Play store and now immediately after the "First Run" initialisation screen, the box abruptly powers off and I have to disconnect and reconnect the power lead to boot it up again ! Ive tried unistalling and reinstalling Kodi 3 times now with no success - any ideas how I could fix this please ?
                            Other than that the ROM is working great - so thanks !
                            I have the same issue. You ever find a fix?
                              it has ftmc installed basically an off shoot of kodi 16 you have to uninstalled it first to install kodi
