Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
Changelog V2:
- Brand new rom, not stock anymore
- Fixed power on from full shutdown with the IR Remote on some boxes!
- Added TWRP
- Fixed adb
- Ported some stuff from Ugoos rom(thks Ugoos for their work)
- Ported stuff include: Samba server, root/unroot(default unrooted), temp, ram, cpu usage etc.. monitor.
- By default the rom is not rooted, so if yo want root enable it in settings.
- Power Menu also ported from Ugoos!
- PS3/PS4 gamepad support(only with cable...)
- Fixed Xbox360 gamepad that showed power menu on dpad left, so no need to xposed fix!
- RGB fix now its on the "stock" android settings(Display)... Can also use the app included.
- New App that controls Brightness and contrast on the fly, and also apply's the rgb fix, cec fix and the saved brightness value on boot! IT NEEDS ROOT TO WORK.. (Many thanks to catharsys for the app
- Gapps updated!
- Only 2 launchers (Launcher3 and Lighthome)...
- Fixed a google framework crash.
- Long Press Menu button hide/show upper/bottom bar
- On the IR remote press "Setup"(red) button and it brings APP SWITCH...
- Updated supersu app so no need to be updated from playstore to update "su" binary.
- Some other stuff i cant really remember anymore.... lol
- And many thks to trebor for the beta testing
- My Proper RGB FIX you need to flash this RGB FIX by recovery, you will after this experience some power off problems(it take some tries to fully power off...) and sleep led problem!
- Only update "su" if you are going to to stay at root if are not going to stay at root and you are going to be doing a lot of changes between the two dont update it! Or you will get a boot animation loop...
- On Mx Player disable in the settings the "Playback settings/ HDMI self-adaption", or else you may(or not) experience some screen going black(but i think this is more a tv problem than a rom problem...)
- You may loose sound when enable my rgb fix on my kernel only (disconnect the hdmi cable and connect it again to solve it)
- Miracast only work if the box its connected to a N wifi network(it wont work on AC) and in Miracast setting change to SD resolution, and it should work but sometimes takes some tries.
- Ugoos Firefly only works on their kernel...
- MIx of stock and new stuff.
- Netflix, youtubeTV playstore...etc... fully working
- Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
- New Launcher.
- Miracast working (check bugs below for how to make it work)
- CPU/GPU temperature should be a lot better now!
- Proper rooted.
- Added CEC fix for remote control not working after power off/power on (sleep mode also) (Many thanks to catharsys for the debug and fix)
- RGB Fix in settings
- Working Screen Rotation in settings.
- FTMC 16.1 Build 21
- initd.d support.
- Network tweaks. (On N networks bw around 30 to 44mbits, and on AC networks from 200 to 230mbits on cable well... from 500mbits to 948mbits) i have a 1Gb/100mbit connection!
- Permissions fixed.
- Sleep working, full poweroff also working.. but not the power on from full shutdown with the IR remote!
- Kodi Brightness fix (videos...)
- Brightness fix for the system, if you guys want more or less brightness simple go to "/system/etc/init.d" and edit the file "1brfix" and change the value in here (echo "10") save and on the next boot you have the value you put it. A small bug, the 1º time the box boots after flash, its not working it only start working after 1º reboot/shutdown.
- Removed background logging.
- CEC disabled by default.
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Gapps Updated!
- Added Xposed Framework
- Other small fixes and optimizations!
- Power On from full shutdown not working with the remote
- Home in setting to change the default launcher it crashes, use pop up for now!
- DOWNLOAD HERE SCV2 FOR H96 Pro+
- MD5: 232ACA1D6DC90231312A863BD38E8253
- Use usb burning tool....
- Watch out this box have 2 hidden usb ports and the OTG port or is the one near the power plug or the one near the ETH plug but that one is hidden....
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
