[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
Originally posted by ReaperMan View PostHeya,
By HW problems..do you mean something like...Plug in the box and watch the blue light and have no signal...then unplug and replug and blue light but no signal...go away and make coffee and after hmm... 2 minutes watch the box suddenly boot-up like there had never been a problem?
If that is what you men by HW problems then I have a second box(Fasttech) that is wonky, but, this has not happen every cold boot.
I see the potential of the 3g/32g combo. 3 gigs of ram makes a difference especially in Kodi/SPMC. The s912 chip seems powerful enough...just quality control is cheap-out with H96 Pro+?
Reap
so I'm at a loss now could there been a chance I deleted the boot loader first time I done it any ideas or help would be much appreciated.
Heya, @ wush15
Take a look at the "' .ini" file on your micro-sd and if erasebootloader=1 then yes you did erase it, but, I saw a sample file on these forums and the member had selected erase(in their sample " .ini" file and had reported success) I can't locate the reference link ... my erasebootloader=0, so not sure of your situation.
If it still manages to turn on be thankful...or try to return for repair. I'm about to contact Fasttech about this problem on my second China-box...maybe they will be helpful?
Reap
Originally posted by Snstr Strmr View PostI tried to download SCV1 about a half dozen times, and no matter what I do the image is corrupted so it's unusable. I'm pulling my hair our because I have 5 H96 pro plus's in my house and the wifi problem is driving me nuts.
Just downloaded and no problem here... the MD5 is for the zip and not for the IMG inside it!Last edited by Snstr Strmr; 03 February 2017, 20:27. Reason: It turned out the issue was that the micro sd I was using is corrupted. I swapped it out for another one and it worked. The first box ended up getting bricked, but the second one is working great! Tha
Hello superceleron, I ve sent you a beercheck ppl.
I bought the H96 Pro Plus (3/32) and ... damn, wi-fi was not hiting more then 24 mbit/sec on 5ghz AC wi-fi, got me so frustrated... anyway, I used the SD card method to flash your rom and ... BOOM.
DTS passtrough also did not work previously, now everything works like a charm.
Keep up the good work, the box is a beast, hitting 47K in antutu, can`t wait to see your next editions!
p.s. I had to rename the img to update.img and edit the .ini on the SD card - have in mind guys.
Agree... That was a little disappointing to me, as the box was advertised with AC 5Ghz... but.. yep, can not make more than 24 mbit/sec, and it`s not enough to stream 40GB mkv from my NAS. I am using a TP-Link Archer C2 AC750, which is not also the best router, but my mobile phones are able to reach 50 mbit/sec download via Wi-Fi, guess they have better wi-fi chips... was thinking to buy an USB wi-fi antenna and hook it in the box... but I am not sure that drivers are arround so... let`s see, probably for streaming 40 gb+ mkv files - ETH is the best.
Or probably soldering an antenna to it?!
Aaa, that`s good news, I cannot still shut it down or power it on from the remote, waiting for the next release: )
Yep... the thing with the wi-fi speed is not good. I have an old router (WRT160n) that I configured and used as a repeater, but it is 2g only, cannot repeat/amplify the 5G damn... and 5g supposed to be better for hd vid.
There are currently 2053 users online. 1 members and 2052 guests.
