[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
    Yes and also SPMC!
    What you recommend for this box?
      The box works fine for me . I installed kodi 17 and spmc . brightness is fine as is for me . mods I did was cut out the extra USB ports in the case so I have 4 working usb ports , added coolling vents top and bottom of the housing and 1/4 rubber feet to bottom of the box .
      can you not adjust the brightness on the Tv screen itself ?
        You can extract it from my rom img.
        Thanks! I was trying to do that before asking here. What tool do you use?
        I tried a bunch of windows based ones and nothing worked. Have to hit up Linux instead?
          in windows use amlogic customization tool, the in tmp inside the app installation folder check level1, and should be there with the name recovery.PARTITION....
            Thanks again. I was trying to use generic android tools. Didn't think to use the amlogic tool.
              Managed to extract it. Here is it for anyone else who finds themselves in a similar position.
              https://mega.nz/#!usIDmaTR!9Zw65_9aGIjZta-LPnc2sL2CQvflcVwNfcwA0uHuwDM
                Now I have another question. How can I flash the bootloader.img and logo.img? TWRP doesn't let me select those partitions. Only recovery and boot.
                I've flashed your boot.img which is not rooted. Doh. Now I need to work out how to re-root it.
                  what do i use to back up my apps,etc to flash from v1 to v2? titanium back up?
                    Hi guys! Help me! My box H96pro+ 3\32, Board Q9377, flash memory Samsung 525 KLMBG8FE4B-B001, ROM PPE-09-093-DG died!!! Unresponsive! When trying to flash, comes to 2% and gives an error. What do I do? How to revive a corpse? I apologize for my English, I translate online the translator!
                      Three questions.
                      - Can I do the below with V2 rom?
                      - Is there any chance the issue with smooth playback on h264 will be resolved in any new rom releases?
                      Sommerman wrote on 02-02-2017, 04:56:
                      This box cant stream 4K h264 movies in Kodi when amcodec enabled. Is there any way to fix it?
                      - what is the best Kodi version I should use with v2 rom? 16? 17?
                        Originally posted by futr0
                        Three questions.
                        As far as I remember someone mentioned it works if you use FTMC or SPMC but not Kodi.
                          On every H96 Pro+ I flash with V2, the wifi disconnects after about 50 minutes and has to manually be turned back on. In V1 the wifi disconnected if the router was reset.
                            Kodi Tips An Tricks - Kodi brightness and contrast settings dont work fix - Box to dark fix
                            Screen Adjuster Free link https://play.google.com/store/apps/d...nslab.sa&hl=en
                              This is my H96 Pro+ Amlogic S912 Octa core Android 6.0 7V B0x RAM 3GB ROM 32GB 2.4GHZ&5.8GHZ Dual WIFI BT4.1 HDMI H.265 4K Smart Media Play
                              H96 Pro Amlogic S912 Octa core Android 6.0 7V B0x RAM 3GB ROM 32GB 2.4GHZ
                              Can I use this rom?
                              Package Yes
                              Brand Name beelink
                              Model Number H96 pro+(3G+32G)
                              Remote Control Included
                              RAM 3GB DDR3
                              Memory size 32GB EMMC Flash
                              WIFI 2.4GHZ/5.8GHZ 802.11a/b/g/n /ac
                              Ethernet Ethernet 100M/1000M
                              Bluetooth BT4.1
                              HDMI HDMI 2.0 up to 4K2K@60FPS
                              Android OS Android 6.0 OS
                              CPU Amlogic S912 Octa core ARM Cortex-A53 CPU up to 2GHz (DVFS)
                              GPU ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
                              Model No H.264-H.265,4Kx2K 60FPS, Android TV BOX,HDMI 2.0
                                yes you can
