[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
I will totally agree with your assessment. It failed three times, last try was newest firmware from 4pda.ru.
I've contacted Fasttech and will see if they can repair faulty unit(how much $$, shipping and time) Shipping to China costs an arm and leg. Hopefully they respond after their New Year.
Thanks for everyone's input.
Reap
Originally posted by superceleron View Postits works? lol maybe is my remote...I ordered it from here: https://www.aliexpress.com/item/3GB-...608.0.0.tVMIds
Heya,
I've tried 2 remotes on 2 boxes and the boxes power-on from full shut-down.
Two concerns have crept up.
1. The mouse pointer disappears (once in a while) at desktop and sometimes in SPMC 16.5.5...sometimes it is ghosted on lower layer of SPMC screen (Amlogic Codec?)
Unless another app re-activates/redraws the cursor, a reboot is needed.
2. The sound does not always initialize on start-up or becomes disabled at some point. (Does anybody else have slighly garbled sound when running Antutu Marooned and Garden test?)
ReapLast edited by ReaperMan; 28 January 2017, 03:57.
In addition to this issue, I noticed as well after restart
The device turns on and then turns itself off and need to switch it on by disconnecting and connecting electricity.
Hi, I updated my H96 pro box using the Micro SD method - all is working OK except I could not see the Kodi app. I reinstalled 16.1 from the Play store and now immediately after the "First Run" initialisation screen, the box abruptly powers off and I have to disconnect and reconnect the power lead to boot it up again ! Ive tried unistalling and reinstalling Kodi 3 times now with no success - any ideas how I could fix this please ?
Other than that the ROM is working great - so thanks !
Originally posted by superceleron View Posthmm.... so its my remote... damn... well np... i will fix it!
1º yes i also notice the mouse bug, need to see where is the problem, ghosted i dint see it but im not using the now
2º like i said above im not using the box now ( to much to do...), so dunno for now!
Originally posted by superceleronwell its the same boxmaybe my remote have some problem...
Anyone else the remote works to power on the box from a full shutdown?
Cheers
Sendt fra min SM-G935F med Tapatalk
There are currently 1296 users online. 2 members and 1294 guests.
