[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
Heya,
I quickly played with Antutu on the three China-Boxes. First score is averaged pre-flash. Second score is best obtained post-flash
1. The Alfawise scored between 42000-43120. PULSE chip H5007NL 1640-M/ ram chip 51x16 DDR3 1648 c6l
2. The 2nd box between 39966-40512.
3. The 3rd scored between 39400-40259
4. The 4th was about 39600- Dead. Pulse chip H5007NL 1650-M/ ram chip ppe09-093 DG (chips on bottom of board were also different)
I would attribute the Alfawise generally higher score to having a different Samsung Nand and ram chips.
The Alfawise also had a unique Thumb print on the micro-sd casing and a dirty bubbled blob of(?) on one of the ram chips.
Reap
Originally posted by Barra EdinazzuI also have the problem with the power off with the remote, was working fine before the flash.
So i think its not the remote.
Hope you find the time to correct that.
Sendt fra min SM-G935F med Tapatalk
im starting to think its a batch of this boxes that comes with some kind of hw problem.
It seems they used a mix of rams, i think they just grab ones laying around at the time and put in it, since my box have toshiba emmc and 2 types of ram chip... hynix and micron...
Mixing ram brands its not a good ideia...
Who let me think is a Hw problem...
Originally posted by Classicman View Post
Just out of curiosity Sommeman, which of the two usb ports did you use to flash image or was it one of the usb ports that are hidden within the box pictured here http://freaktab.com/forum/tv-player-...l-wifi-and-bt?
Heya,
By HW problems..do you mean something like...Plug in the box and watch the blue light and have no signal...then unplug and replug and blue light but no signal...go away and make coffee and after hmm... 2 minutes watch the box suddenly boot-up like there had never been a problem?
If that is what you men by HW problems then I have a second box(Fasttech) that is wonky, but, this has not happen every cold boot.
I see the potential of the 3g/32g combo. 3 gigs of ram makes a difference especially in Kodi/SPMC. The s912 chip seems powerful enough...just quality control is cheap-out with H96 Pro+?
Reap
There are currently 1617 users online. 0 members and 1617 guests.
