[ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV2 ROM (DDR3 ONLY)
Originally posted by joemilan View PostHi guys, i have buyed a Alfawise H96 pro+ from Gearbest since 15 days ago, how can i know my ram type??? i had opened case and saw on pcb but i not see any ddr code on chips.....
Can i flash SCV2 or SCV3 rom without problems?? Thanks
You cant install this software on the alf ddr4 so thats the way to tell There 2 options for firmware my debloated or the stock one released. Ill be trying some newer firmware shortly now that i have a stock image to flash to return to.
Originally posted by hujik View Post
V2 installed and working well - it seems almost without issues.
Few observations:- For uploading image using SD card - image has to be named "update.img" as pointed out many times. It is crucial!
- after image loaded - first boot can take few minutes.
- Sometimes it happened that device rebooted "itself" ... no pattern found ... but recently so far without random reboots ...
- to install latest Kodi (17.x) curent one (FTMC) needs to be uninstalled first. Than install 17 from google play. But it remove brightness fix!
- Kodi backup from Kodi 17 is not fully compatible with older version of Kodi (FTMC installed in the image). Loading such backup will somehow corrupt Kodi ...
There is a feature related to HDMI which somehow "synchronize" frame rate or what with movie source somehow ... it should leads to more smooth experience ... but since I have disabled that, described issue has been reduced ...
No photo posted in 333 you posted in 330 anyways looks like ddr3 in yours.Last edited by scooter2014; 28 March 2017, 20:22.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
My alfawise h96 pro plus,not start anymore, it stuck in red light...any solution?
I have only replaced superuser (uninstalled with TiBu) with superSU before, after restart and it block on H96 Pro+ yellow logo, so I off box and not more restarted
There are currently 2304 users online. 0 members and 2304 guests.
