seems like it that the USB Ethernet only gets a IPv6 adress........
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
just been playing with terminal a little more
seems like it that the USB Ethernet only gets a IPv6 adress........Home Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
I found this page with Build.prop tweaks
somewhere it says :
11. Support for ipv4 and ipv6.
persist.telephony.support.ipv6=1
persist.telephony.support.ipv4=1
i dont see these lines inside your build.prop
im gonna test if this will work by adding theseHome Cinema Setup Livingroom:
got it working now.... on the original Ethernet port
i did a dhcpcd eth0 on the terminal
netcfg eth0 dhcp
and now it all works
EDIT:
system crashed, ip stuff all gone again.... not working (After i wanted to connect to nas it rebooted and it was all gone)
at least i know for sure the hardware aint broken, before it broke down i tested ethernet @ 60Mbps so port is working..... its a firmware problem for sureLast edited by LeXXoZ; 16 August 2013, 00:22.Home Cinema Setup Livingroom:
Originally posted by LeXXoZ View Postgot it working now.... on the original Ethernet port
netcfg eth0 dhcp
EDIT:
Just to check, it failed only when you were trying to connect to the NAS? Any issues connecting to Google servers?
netcfg eth0 dhcp
EDIT:
i dont know what is cousing this.
maby some hardware changes.
you can put thouse comand into init.d to automate the proces.Everything is possible if we work together!
Originally posted by lewy20041 View Postits strange. its working for me and others,
Yeah its strange, im gonna try to reproduce the fix and put that in init.d file to see if it keeps working
Thanks for your help anywayHome Cinema Setup Livingroom:
Originally posted by wasser View Postkernel 1080p uploaded, you are wellcome!
thank you wasser!_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
AW: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Gesendet von meinem HTC One mit Tapatalk 4
wasser can you post a link to it?;p
i will post a new hfw ver today based on minix firmware.
it will have all futures of hfw and minix firmware and thanks to you 1080p support
i think this ver will dont need any more updates for much longer time.Everything is possible if we work together!
There are currently 4399 users online. 2 members and 4397 guests.
