thanks
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
its uploaded.
check first postEverything is possible if we work together!
Re: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by lewy20041 View Postits uploaded.
check first post
Ethernet, wifi, analog audio all good...
I've noticed the power button on screen kills power quickly but the device seems to restart itself without touching it or its remote, seems my satellite remote wakes it, but then there's no response from using the supplied IR remote... Odd.
Would be nice if the on screen power button gave shutdown options like you get when pressing physical power button.
Other thing is google play music now plays the first track AND a couple of seconds of the second track before going silent... So SOMETHING has made a difference!
Thanks dor the work guys!
Mark
Sent from my GT-I9505 using Tapatalk 2_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
are u using an external player ?
yesterday i ran a classic movie, saving private ryan on 1080p rip 10 Gb movie on the box through MX Player Pro and it ran alright. but i noticed that sometimes it had frameskipping. 720p movies run fine without any hassle. it has problems on playing parts where there is alot of action on the screen, lets say watersplashes (Scene in the boats on Saving Private Ryan where they enter the beach)
playing the movies from a NAS through CIFS mount so it thinks the movies are on SDCard, and speedtest on lan is +60 Mbit (Wired) wireless gives me a average of 35 / 40 Mbps (But that is variable)
XBMC Player itself isnt the best around i noticed, because of HW AccelerationHome Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
I'm using the 1.2.1 Rom. (downloaded yesterday) Great rom. Lewy, you are a genius.
I have a few small issues
Keep getting the message: "Unfortunatly the process android.process.media has stopped". Happens random.
Shutdown is not working as expected. When I use the buttom in the statusbar. The device is instantly down. Blue light on button is off and I have to power it off to be able to start the device.
Originally posted by Tooz View PostSo you say the problem is with the XBMC and not the device.....
setting external player would fix (or play it better) then XBMC player?
And Thanks for the explanation !
the internal player has issues with hardware accelerationHome Cinema Setup Livingroom:
Originally posted by LeXXoZ View Postyou could config XBMC to use an external player. thats how i do it and it works fine
I have had mixed success with the various libstagefright test builds using the internal player but, as noted above, hw acceleration in the android builds is still not very stable. YMMV, as always.
some pros and cons of 1.2.1
just tried 1.2.1, i think 1.2.0 is actually better (less serious bug)
as lewy20041 mentioned,
1, no webcam audio, no usb audio the sound input/output cant even detect usb sound card device
2. the original IR remote doesnt work !
3. if i choose shutdown, it will wake up again immediately AND also all the connected usb keyboard, air mouse don't work after wake up
4. will pop up "xxxapplication got no response, wait or kill?" box just after restore
5. it seems that there is still no way to "dts/ac3 passthrough" (or i dont know how to setup mx player....??)please correct and teach me if I m wrong.
However, the screenshot and autohide are really two great functions, keep it up!!
One question, it there any method to "upgrade" the firmware and keep old data rather than "restore" every single time, and need to reinstall all the apps and settings after restore????
hope this rom will be better and has more integration of function from other models of droid tv
Thanks,
tmac666
hold shoutdown button longer for shoutdown menu.Everything is possible if we work together!
did you trayed on stock player?Everything is possible if we work together!
There are currently 3081 users online. 0 members and 3081 guests.
