K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
    Originally posted by wasser View Post
    it seems hdmi code doesn't work correctly for r-k42, have you seen "the screen flickering from time to time." in
    leolas test kernel for k-r42?
    > sound settings no spdif.
    i'm working on this, hope to get the fix soon
    >can you aplay statering fix for videos?
    what do you mean here?
    no flickering on leolas kernel:"
    also i found that sound is disapiring.
    stutter video fix:
    Everything is possible if we work together!
    ApkFreak
      uploading new firmware...
      ApkFreak
        havent got the DTS working yet, should it work with MX Player ?
        im using MX Player Pro and grabbed that latest codec from xda forum
        just played a 1080p videofile and network seemed stable, but sometimes it looks like it skips frames during playback
        Home Cinema Setup Livingroom:
        50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
        Bedroom Media Setup:
        32" Philips LCD -
        KR-42 wasser rom
          try new firmware and post back ok.
          ApkFreak
            ok will do
            32" Philips LCD -
            KR-42 wasser rom
              Re: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
              Originally posted by michael2t View Post
              I have a USB power Hub and I can Plug my Mouse/Keyboard Device Into it and it works Fine.
              Or I can Plug the USB Hard drive in to the Hub only and The Player works fine ... But When I plug My USB Hard drive Into The Powered USB Hub and the Keyboard/Mouse and Hard drive Both Stop working ...
              My guess is the hub isn't providing enough power for everything and the usb port in the android device is probably too weak to make up for the lack in power. Also usb can be flakey, I've had the same device and cable work on one computer port and not another...
              Sent from my GT-I9505 using Tapatalk 2
              _________________________________________
              Out: USB audio, HDMI
              In: Logitech K400 keyboards
                first post updated
                ApkFreak
                  Originally posted by lewy20041 View Post
                  first post updated
                  Thanks again !
                  downloading now
                    First thanks wasser for your help, I was triying to compile a working kernel for the k-r42 with 1080p and 720p with video fix, but the bigger problem is that without the device I cant advance fast enought. If I can help you in anything only tell me and I will try to help. If you want, you can use my github to take the kernel sources I use in:https://github.com/leolas/ANDROID-KERNEL-QX1
                    You need to change in arch/arm/board-rk3188-box.c:
                    Code:
                    		.name          = "act_dcdc4",   //vccio //modded by leolas stock:3300000 working:3000000
                    		.min_uv          = 3000000,
                    		.max_uv         = 3000000,
                    for
                    Code:
                    		.min_uv          = 3300000,
                    		.max_uv         = 3300000,
                    and
                    Code:
                    		.name          = "act_ldo6",   //vcc_jetta //leolas modded stock:1800000 wifi working:3300000
                    		.min_uv          = 3300000,
                    		.max_uv         = 3300000,
                    for:
                    Code:
                    		.min_uv          = 1800000,
                    		.max_uv         = 1800000,
                    my last .config file if you want to use it how the base config is:http://cloud.freak-tab.de/public.php...95fcee1995e58e
                    In this sources video is fixed. If I can help in something please only tell me. Try to make a kernel without the device is a nightmare. Thanks again
                    My devices:
                    Gearbest.com)
                      First Test of 1.2.1
                      First test of 1.2.1
                      1) The default Little Remote does NOT work with ok Button any more
                      2) The Menu Button on the Remote does NOT work any more ...
                      3) Check Auto Hide System Bar on display and it will never go away ...
                      Hit the >> down on the screen and it just pops backup and will never go away ...
                      4) usb Keyboard's Enter key work Fine.
                      First Look ...
                      Michael T.
                      3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
                      CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
                      Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
                      Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
                        i was expecting 1080p rom today
                        i dont wanna bother anyone but when can i learn what is nfs mode,
                        what is this
                        Code:
                        su        mkdir /sdcard/nfs                                                             busybox mount -o rw,intr,soft,nolock 192.168.1.102:/mnt/HD/HD_a2 /sdcard/nfs
                        some questions for patient experts :
                        1. dts fix mean dts passthrough? because my old version MX Player was already decoding it?
                        2. Rockchips HomeMedia was good to control it with my cell , how can i install it?
                        3. I guess Wifi Display need same program to be installed on the phone to work, i got it via root explorer and tried to install to my phone but failed , any other way you can recommend?
                        thanks beforehand
                          Homemedia
                          Hello albatros79,
                          You do NOT need wifi on the player only on the phone and both need to be on same network ...(so either ethernet or wifi will work But you do NOT need both turned on one or the other) ...
                          Download Latest Firmware and Unzip it ...
                          In the Folder Called "Orig apps" On your PC you will Find the two apps You need .
                          On The Player Load the eHomeMediaCenter_box.apk
                          On You phone Load RKGameControlSettingV1.0.1.apk(Via Wifi )
                          Then I always Reboot ...
                          I think that answers Your Remote Control App Question .. Others will have to help you with The Other Question ..
                          Michael T.
                            found a webcam problem.
                            rom delayed for tomorow.
                            ApkFreak
                              Originally posted by LeXXoZ View Post
                              weiiiiird
                              i just reflashed your rom, and now Ethernet works ....... i dont get it anymore whahahahahaha flashed the rom few times last week and it didnt worked
                              Mine is still not working after I flashed 1.2.0. Not sure why as well. Anyone can help? Thanks in advance. I was having the same symptoms as LeXXoZ. eth0 is showed as up, but it is not able to get an IP address. Setting a static IP address does not help as well.
                                rom in first post.
                                the new kernel dont have webcam audio support.
                                no fix for no
                                ApkFreak
