Sent from my GT-I9505 using Tapatalk 2
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Re: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by bloatman View Post
Sent from my GT-I9505 using Tapatalk 2_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by yurmala View PostHi, dear wasser!
I try it.
nfs.ko successfully loaded. That's good!
cat /proc/filesystems show me nfs and nfs4
But! When i try mount nfs - player go to reboot.
I try 2 type of mounting:
1) Mount Manager
2) via terminal (su mode) - busybox mount -o nolock,ro,hard,intr <host>:<remotedir> <localdir>
In both case - full reboot.
I don't know, maybe it's only my problem...
I'm use the stock kernel (minix x5 (rk3066), android 4.2.2, kernel 3.0.36+)
Originally posted by karel View PostI got the same problem. Insmodding the drivers is done succesfully. When trying to mount a nfs share using the "busybox mount -t nfs -o rw,nolock 192.168.1.101:/volume1 /sdcard/xxx" command the system reboots. (Also with the new compiled drivers (
Originally posted by lewy20041 View Postthx to "wasser".
your modules are working great.
nfs support build into the rom.
i will update firmware on 14/08/2013
Will multiuser feature work in your next rom version?
Originally posted by fredphoesh View PostYeah, that's been with all versions of the rom, stock was the same from what I remember...
I have installed a shutdown app as a solution but one thing i dont like about shutdown app is that it power off instantly without closing any services (on stock rom it delays 2-3 secons which seems safer), i didnt had any problems though.Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
Originally posted by psychorat View PostYes this problem occurs on all custom versions. On stock rom shutdown works well.
ok, so if stock is ok with shutdown, i wonder if spotify / play music will work better on stock too!? im gonna try!
cheers,
mark._________________________________________
on stock firmware that you can download on geekbuying blog shoutdown dont work.Everything is possible if we work together!
Originally posted by fredphoesh View PostHi psychorat, welcome back from your holiday! im off to greece next week!
cheers,
mark.
@ lewy20041 : Yes im talking about the rom that came with the device. Unfortunatelly i didnt backup that rom to compare it and see what the differencies are. I hope somebody will.. Anyways im very happy with your ROM as it is and looking for the next update.Device : CS918 --> Sony Bravia 32" 720p
Originally posted by psychorat View PostThank you! i came back for 1-2 days and im leaving again. Thankfully im close enough from my house in Athens (about 1 hour) and its easy to take care some business without breaking my vacation
I just flashed the "stock" image from geekbuying, but it does not shut down properly, and
spotify still has spotty playback
play music still only plays ONE TRACK!
aaauuugghhh.....
REALLY annoying.
I am considering selling my box after finding out which one does work properly with Google Play Music and Spotify... that is really important to me since it is how I listen to my music if not on xbmc locally stored.
Tx for the support and feedback guys,
Mark._________________________________________
as to storage space. its normal (system take some space)Everything is possible if we work together!
Originally posted by albatros79 View Postwhen i connect my 1.5 tb 2.5" seagate hdd, it connects and disconnects continously,
There are currently 4222 users online. 0 members and 4222 guests.
