many thanks @Magendanz for your nice work!
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Hello,
ok i'm back.
By pressing the reset button, I have no more problems during the flash (erase bootloader).
On the other hand, the Android TV remote still don't want to connect and DTS don't work for me (no sound unless i activate mix in stereo). Dolby works well.
My setup:
- hdmi passthrough enabled in android setting.
- passthrough enabled (and option below) in kodi.
Thanks for your great work.
Originally posted by Gazouille View PostHello,
ok i'm back.
My setup:
Thanks for your great work.MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
can't confirme with Beelink GT1_110M0 ROM . My previous rom was your nano 109M0 with which i already had the pb.
I read a lot of thing this morning and I came to the same conclusion as KAA . I will test SPMC this evening.
I keep you informed.
Hello,
my test with this ROM, without new installation :
-Kodi 17 official: even after one night of rest... No DTS :-)
-smpc: DTS ok but no DTS HDMA and really not user friendly
-kody shitty: DTS ok and no DTS HDMA.
-ftmc build 23: don't want to install.
-ATR don't want to connect like yesterday.
Thanks, I will keep kodi shitty and retry installation of ftmc
Guest
This ROM has both the Gamepad Pairing Service and Pairing Tutorial installed, but these really are designed for the Gamepad for Nexus Player. Some other Bluetooth controllers may work, but definitely not the Xbox 360 wireless controller, which doesn't use Bluetooth. Basically, the compatibility should be the same as the Nexus Player.
There are currently 2529 users online. 0 members and 2529 guests.
