[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Okay, that's just showing a postage stamp size image, and there's no way that I can read the chip labels. Using a magnifying glass, can you see anything with the numbers 62X2, 4354, 4356, 6212, 6255, 6335, 43458 or AP6330?
Originally posted by jeffskodi View PostEverything works perfect except remote control not working on this Rom...running Tronsmart S96 how do get this works?thks
I have a little folder with Tanix, MiniM8, Nexbox ... remote.conf
I'm looking for a T95K pro remote.conf, didn't backup mine.
Someone? (Magendanz you have it in store?:-) )
Originally posted by Cinquieme View Post
Well yes it's a general issue. You have to replace the remote.conf file in /system/etc with your Tronsmart S96 remote.conf file
Guest
BTW, last night I added an OTA updater as a flash option, which is considerably smaller than the Amlogic burn package used by USB Burning Tool. It also has the advantage of being able to be installed without wiping user data. However, I haven't yet been able to successfully sign the update with a valid OTA cert, and so you'll need to install it from TWRP. Ultimately, once I get this signed you should also be able to install from an OEM firmware release with stock recovery, but I'm not quite there yet.
Guest
Cinquieme , it looks to me like you've got an AMPAK AP6330 on that T95K Pro box. Let's see if we can't extract those drivers from the Sunvell firmware. (Actually, I'm curious if I can't pull the wireless drivers for ALL those chipsets supported in that Sunvell ROM and put them into one updater.)
Update: Wait, is that last photo from another board? Regardless, the 6335 chipset seems to use the Broadcom BCM4335 drivers and those are also bundled in the Sunvell firmware.
noi know that are some floating around now if they are good or not(secure).. i dont know!
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Magendanz View PostCinquieme , it looks to me like you've got an AMPAK AP6330 on that T95K Pro box. Let's see if we can't extract those drivers from the Sunvell firmware. (Actually, I'm curious if I can't pull the wireless drivers for ALL those chipsets supported in that Sunvell ROM and put them into one updater.)
I have a "SM63353110 IT-A3" not a "AP6330" indeed.
Well that would be great to have the bundle of drivers included
There are currently 1276 users online. 0 members and 1276 guests.
